[geos-devel] RE: build error on SGI
strk at refractions.net strk at refractions.net
Tue Aug 16 07:42:31 EDT 2005
Chris, my config.status contains 2.1.3
This means that ./configure was able to compute $((3-1)) correctly.
./configure runs through /bin/sh
Would you try and find a working syntax for that operation ?
--strk;
On Mon, Aug 15, 2005 at 12:27:22PM -0600, Chris Padwick wrote:
> Hi Folks,
> I believe I figured out a workaround.  The config.status file contains
> the line
> s, at VERSION@,$((3-1)).1.3,;t t
> which expands to "").1.1"" in the DGEOS version flag below.  If I change
> the line to say
> s, at VERSION@,2.1.3,;t t
> then it works just fine.  Not sure why that would be the case since it
> works ok on linux.  Maybe it's something quirky in my particular version
> of IRIX: IRIX64 dgidev 6.5 01100304 IP27 or the configuration on the
> box.
> FYI,
> Chris
> -----Original Message-----
> From: Chris Padwick
> Sent: Monday, August 15, 2005 10:48 AM
> To: 'geos-devel at geos.refractions.net'
> Subject: build error on SGI
> Hi Folks,
> I downloaded version 2.1.3 of geos and am building it on SGI.  I'm
> getting the following build error:
> dgidev 10:39:25am: make
> Making all in source
> make[1]: Entering directory `/home/cpadwick/geos-2.1.3/source'
> Making all in geom
> make[2]: Entering directory `/home/cpadwick/geos-2.1.3/source/geom'
> if /bin/sh ../../libtool --mode=compile --tag=CXX
> /home/cpadwick/nfs1_oldhome/bin/g++ -DHAVE_CONFIG_H -I. -I.
> -I../../source/headers -I../../source/headers/geos
> -I../../source/headers -DGEOS_VERSION="").1.3""    -g -O2 -MT
> Coordinate.lo -MD -MP -MF ".deps/Coordinate.Tpo" -c -o Coordinate.lo
> Coordinate.cpp; \
> then mv -f ".deps/Coordinate.Tpo" ".deps/Coordinate.Plo"; else rm -f
> ".deps/Coordinate.Tpo"; exit 1; fi
> /bin/sh: syntax error at line 1 : `)' unexpected
> make[2]: *** [Coordinate.lo] Error 2
> make[2]: Leaving directory `/home/cpadwick/geos-2.1.3/source/geom'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/cpadwick/geos-2.1.3/source'
> make: *** [all-recursive] Error 1
> I'm running the following versions of the gnu tools:
> libtool --version
> ltmain.sh (GNU libtool) 1.5.16 (1.1220.2.234 2005/04/24 17:45:58)
> autoconf --version
> autoconf (GNU Autoconf) 2.52
> Written by David J. MacKenzie.
> Version 1.61 of automake
> make --version
> GNU Make version 3.79.1, by Richard Stallman and Roland McGrath.
> Built for mips-sgi-irix6.5
> Any hints?
> Thanks,
> Chris
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
