[geos-devel] Re: freeBSD ports GEOS
Konstantin Saurbier saurbier at math.uni-bielefeld.de
Sun Dec 11 19:16:55 EST 2005
I was not subscribed to geos-devel. So here my reply to streak for the
files of geos-devel:
strk at refractions.net wrote on Mon Dec 12, 2005 um 12:49:12AM:
> [geos-devel included]
> On Sat, Dec 10, 2005 at 08:30:09PM +0100, strk at refractions.net wrote:
> > On Sat, Dec 10, 2005 at 07:39:44PM +0100, Konstantin Saurbier wrote:
> > > Stephen Woodbridge wrote on Sat Dec 10, 2005 um 01:34:03PM:
> > > > Hello,
> > > > I got you email from the freeBSD geos package as the port maintainer.
> > > > I use PostGIS which depends on GEOS and I have had a problem with the last two
> > > > upgrades, GEOS-2.1.4 and GEOS-2.2.0 in that these have created libraries of
> > > > libgeos.so.3 and libgeos.so.4 respectively. The problem is that these should
> > > > probably both be libgeos.so.2. Well at least PostGIS expects the library to be
> > > > libgeos.so.2.
> > > > I have copied Strk the GEOS developer who might have more to comment on this.
> > > > Any help with this would be appreciated by all freeBSD users of these packages.
> > > Have you tried to just create appropiate links? For example:
> > > ln -s libgeos.so.4 libgeos.so.3
> > > if this will fix your problems i will patch geos to create these links at
> > > installtime.
> > > Be adviced that geos will not compile on FreeBSD 4.x. I will contact the
> > > GEOS developers later on, but i had no time until now.
> > I have access to a FreeBSD 4.2 - I'll test this and let you know.
> I successfully build 2.2.1 (out tomorrow) with g++ (GCC) 3.4.4.
> I confirm that libgeos.so comes out versioned as .4 (libgeos.so.4)
> SONAME sems to be libgeos.so.4 but didn't have readelf(1) available
> to check this.
This sounds very good. I will write a patch for the geos port as soon as
the new version will be out. Very nice and fast work :-)
Thank you very much!
> I assume this is a decision taken by libtool, probably due to
> requirements of the FreeBSD dynamic linker. Basically it looks
> like on Linux an addition of interfaces (in libtool terms) is binary
> compatible while in FreeBSD it is not.
> Mea culpa: I shouldn't have incremented INTERFACE_CURRENT for C++
> lib as there really haven't been any additional interface there.
> I wanted to encode addition of the C-API, but that should have
> been reflected on release version only, not C++ library SONAME.
> The symlink should work fine (as no binary breaks has been introduced),
> but its really not that clean and should be avoided in future.
Oh sorry I've forgotten to CC you. The naming problem is already solved it
is no problem of geos. In fact it is only a problem of the freebsd package
postgis not even the source of postgis.
What happened? When i upgraded geos to version 2.1.4 and 2.2.0 the postgis
port was adjusted do use libgeos.so.3 respective libgeos.so.4 but because
of other errors in the postgis port from FreeBSD the build cluster was
unable to build postgis. The result was the occurring error message of the
postgis packages. This message can be fixed with a simple link but is not
needed after the postgis packages has been fixed and rebuild.
Best regards,
Konstantin Saurbier
Konstantin Saurbier                Tel.: 0521 106 3861
Computerlabor Mathematik                        U5-138
Universitaet Bielefeld             Universitaetsstr.25
33501 Bielefeld
email:                  saurbier at math.uni-bielefeld.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20051212/27d2ac40/attachment.bin
