[geos-devel] GEOS Swig Patch - New support for Ruby
Charlie Savage cfis at interserv.com
Thu Dec 15 13:24:11 EST 2005
Hi everyone,
I have just provided a patch to strk that updates the GEOS swig
bindings.  I have not included it below, because it is quite large due
to the inclusion of SWIG generated wrapper files.
What the patch does:
* adds a swig/ruby directory - this includes bindings for the Ruby
language plus a port of example.cpp
* significantly modifies swig/geos.i.  Language specific functionality,
such as renaming methods and classes, was taken out and moved to
language specific files (python.i for python, ruby.i for ruby)
* Adds typemaps to support istreams and ostreams - this makes methods
like WKBReader.printHex and WKBWriter.write accessible now to scripting
languages
* A few other bug fixes like keyword conflicts in Python (the print keyword)
What needs work:
* As always, the key issues with SWIG bindings is memory management.
Right now the bindings assume that any time one of the following 3 types
is passed in as a parameter to a method, then the method's class takes
over ownernship of the parameter:
geos::CoordinateSequence *
geos::LinearRing *
std::vector<geos::Geometry * > *
I'd guess this is not true.  If someone who is more familiar with the
GEOS C++ api could let me know, I can fix this
Similarly, a brief look through the GEOS api shows some methods return
new objects.  SWIG must be told about these methods.  So once again,
does someone have a list of these methods?
* The example.py and example.rb files crash when trying any of the
combination methods (union, intersection, etc.).  My guess it has to do
with the memory management item listed above.
* The bindings compile against the C++ api, not the C api.  This could
be changed, but would require a significant amount of work.
Hope people find this useful.
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20051215/331c6a71/smime.bin
