[geos-devel] JTS/GEOS performance - smart-ptr vs ref counting
Ferdinando Villa ferdinando.villa at uvm.edu
Tue Feb 1 10:36:41 EST 2005
>> One thing that would probably speed things a bit is to inline the
>> trivial constructors and destructors :-)
>I would do this, but is it possible to inline functions w/out breaking
ABI ? Will using the 'inline' keyword be enough ?
I may be wrong, but I suspect this is the kind of thing that a good
compiler could optimize away anyway.... maybe it's worthwile to check
gcc's docs or run some simple tests to make sure it really matters,
before embarking in a boring and unnecessary typing exercise...
ferdinando
--strk;
> It might be worth looking into special memory managers but AFAICT
> most of the 'coordinates' are actually stored in STL vectors and these
> are generally about as efficient as you can get at minimizing
allocation
> costs.
> Norman
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
