[geos-devel] GEOS 2.1.1 sprintf Compile Error
strk at refractions.net strk at refractions.net
Fri Jan 28 09:35:25 EST 2005
On Fri, Jan 28, 2005 at 09:24:54AM -0500, Frank Warmerdam wrote:
> On Fri, 28 Jan 2005 10:56:35 +0100, strk at refractions.net
> <strk at refractions.net> wrote:
> > I've substituted most sprintf calls with use of ostringstream.
> > WKTWriter and (external) MarkupSTL are the only one left.
> > Could you check if CVS version works fine for you ?
> > TIA
> Strk,
> Sorry, I can't build from CVS.  When I try to run automake I get the
> following.  Frankly, while I know it is considered "best practice" to
> not include the derived automake and configure files in CVS, I find
> it makes use of CVS very challenging.  I never seem to have the
> latest automake, autoconf and supporting stuff needed to build
> cutting edge projects.  I am running automake 1.8.3 and autoconf
> 2.59.
You should run ./autogen.sh which would take care of calling the
autostuff in the correct order.
... It works here with automake-1.7.7 and autoconf-2.57 ...
BTW, do the hourly snapshots have the generated files ?
--strk;
> warmerda at gdal2200[13]% automake
> configure.in: no proper invocation of AM_INIT_AUTOMAKE was found.
> configure.in: You should verify that configure.in invokes AM_INIT_AUTOMAKE,
> configure.in: that aclocal.m4 is present in the top-level directory,
> configure.in: and that aclocal.m4 was recently regenerated (using aclocal).
> configure.in: required file `./install-sh' not found
> configure.in: required file `./missing' not found
> configure.in:6: required file `./config.guess' not found
> configure.in:6: required file `./config.sub' not found
> doc/Makefile.am: required file `./depcomp' not found
> /usr/share/automake-1.8/am/depend2.am: am__fastdepCXX does not appear
> in AM_CONDITIONAL
> /usr/share/automake-1.8/am/depend2.am: AMDEP does not appear in AM_CONDITIONAL
> in AM_CONDITIONAL
> source/geom/Makefile.am:6: Libtool library used but `LIBTOOL' is undefined
> source/geom/Makefile.am:6: The usual way to define `LIBTOOL' is to add
> `AC_PROG_LIBTOOL'
> source/geom/Makefile.am:6: to `configure.in' and run `aclocal' and
> `autoconf' again.
> in AM_CONDITIONAL
> configure.in:24: required file `source/headers/config.h.in' not found
> in AM_CONDITIONAL
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
