[geos-devel] JTS/GEOS performance - smart-ptr vs ref counting
Martin Davis mbdavis at VividSolutions.com
Mon Jan 31 19:35:28 EST 2005
That was pretty much my point - smart pointers alone don't produce
memory efficiency, they just make the code safer (and hopefully easier).
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.      www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: Chapman, Martin [mailto:MChapman at sanz.com]
> Sent: January 31, 2005 4:18 PM
> To: GEOS Development List
> Subject: RE: [geos-devel] JTS/GEOS performance
> Martin,
> Smart pointers are one thing and ref-counting (garbage
> collection) are two different but related things.
> Smart pointers help prevent memory leaks.  A smart pointer is
> always created on the stack, when the function ends they
> always go out of scope and their destructors delete their
> encapsulated pointer...therefore, if all heap data is wrapped
> by a smart pointer, if the function crashes you are
> guaranteed that the heap memory will be de-allocated because
> the smart pointer will always be destroyed and will call it's
> destructor. This actually means more vars on the stack, but
> less chance for mem-leaks.
> Ref-counting allows multiple objects to share pointers to the
> same object without the fear of some other object deleting
> that object before you are done using it, and allows you to
> safely pass heap data across function boundaries.  This can
> save huge amounts of memory and debugging.  For example...if
> you have a million geoms that all have a pointer to the same
> spatial reference class then you only need one SRS class
> versus a million of them.  The SRS class refcount will be a
> million and is guaranteed to be around until the last geom
> decrements the ref count to zero.  Also, this way you can
> easily and quickly change a prop on the SRS class that is
> immediately available to all million geoms.  You can also,
> easily re-assign the SRS of an individual geom without
> disrupting the other 999,999 geoms.
> So the short answer is, an enterprise api should have both
> smart pointers and ref-counting available as an option.
> The email I just sent before this one has code examples of a
> smart-pointer template class that does both.  It's based
> after MS COM's CComPtr<> class, but is ansi and will run
> cross platform.  It's small, light-weight, polymorphic and
> works great.  Geos definitely needs this, but it's not going
> to make your app faster, just more memory efficient...and you
> won't have to be calling "delete" all over the place anymore.
> Increasing speed is all about looping and
> allocating/de-allocating in your app.  The more times you
> loop through coords and alloc/dealloc you are consuming lots
> of clock cycles.  Think about what it takes to alloc 20
> classes for each loop in a million features...if you look at
> the disassembler you would be amazed.
> Martin
> From: Martin Davis [mailto:mbdavis at VividSolutions.com]
> Sent: Monday, January 31, 2005 3:50 PM
> I can see how smart pointers can help with program
> correctness.  Do they help with performance?
> > From: Norman Vine [mailto:nhv at cape.com]
> > Sent: January 31, 2005 11:31 AM
> > Martin Davis writes:
> > > Hmmm.  This seems fundamentally the wrong approach.  JTS
> > does not need
> > > the flexibility of linked lists inside CoordinateSequences.
> >  It sounds
> > > like you are trying to build a garbage-collected memory
> management
> > > layer.  This may be the only reasonable solution.
> However, rather
> > > than hacking this into the existing code in an obtrusive
> > kind of way,
> > > it would be nicer to look for a clean, layered solution.
> Are there
> > > any open source GC packages for C++?
> > There are several quality OpenSource C++ Memory Managers
> but ... This
> > is *exactly* the kind of thing that smart_pointers have
> made sort of
> > obsolete  :-)
> http://boost.org/libs/smart_ptr/smart_ptr.htm
> Norman
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
