[geos-devel] Ready for 2.1.2 ?
strk at refractions.net strk at refractions.net
Tue Jun 7 04:05:02 EDT 2005
On Mon, Jun 06, 2005 at 08:46:39PM -0700, Paul Ramsey wrote:
> OK, compiles and runs the XMLTester fine under OS/X 10.4.1
> I'm good to go. Any other test results from other platforms (windows
> anyone? slowaris? freebsd? OS/X 10.3?)
No luck on freebsd 4.2 with gcc 2.95.2 (very very old).
The problem seems to be with stringstreams: unavailable sstream
header - including strstream unavailable ostringstream type.
If anyone have similar problems and possibly a solution I'd
change sstream usage with something else.
--strk;
> cvs -d :pserver:cvs at postgis.refractions.net:/home/cvs/postgis co -r
> branch-2-1 geos
> cd geos
> ./autogen.sh
> ./configure
> make
> cd source/text
> ./XMLTester
> Paul
> Paul
> On 6-Jun-05, at 2:07 AM, strk at refractions.net wrote:
> >We'd like to release GEOS 2.1.2, a bugfix and performance
> >improvement work.
> >Changes since 2.1.1:
> >- Segfault fix in Point::isEmpty
> >- Mem Leak fix in OffsetCurveBuilder::getRingCurve
> >- Bugfix in LineSegment::reverse
> >- Added multipolygon buffering test in source/test/testLeaksBig
> >- Ported JTS robustness patch for RobustLineIntersector
> >- Removed useless Coordinate copies in OverlayOp::mergeZ()
> >- Avoided throws by IsValid on invalid input
> >- Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
> >ostringstream
> >  instead of sprintf)
> >- Better support for older compilers (Polygonizer::LineStringAdder
> >friendship)
> >- Removed useless Coordinate copies in CGAlgorithms::isOnLine()
> >- Added support for polygonize and parametrized buffer tests in
> >XMLTester
> >- Fixed support for --includedir and --libdir
> >- Fixed Z interpolation in LineIntersector
> >- Handled NULL results from getCentroid() in XMLTester
> >- Segfault fix in (EMPTY)Geometry::getCentroid()
> >- Made polygon::getBoundary() always OGC-valid (no LinearRings)
> >- Input checking and promoting in
> >GeometryFactory::createMultiLineString()
> >- Segfault fix in GeometryEditor::editPolygon()
> >Did anyone other then me test the code yet ?
> >It is accessible using the branch-2-1 tag of CVS.
> >Any test or bug report is highly appreciated.
> >Thanks
> >--strk;
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
