[geos-devel] Ready for 2.1.2 ?
Carlos A. Rueda carueda at ucdavis.edu
Tue Jun 14 01:30:08 EDT 2005
I just tried GEOS 2.1.2 (as is available from the website) under
MinGW: MSYS 1.0.10, MinGW 4.1.0.  The only complain was related with
lines 49 and 454 in source/test/XMLTester.cpp:
If `using geos::Polygon' is kept, the compiler complains about
redefinition of Polygon (which I think is consistent with the comment
strk (?) put on that line. However, if the line is commented, the
complain is now that Polygon (in line 454) is not defined. So an easy
solution was just to qualify the usage of Polygon in line 454 and
comment line 49:
line 49:    //using geos::Polygon; // for mingw ...
line 454:   vector<geos::Polygon *>*polys = ....
The build now succeeds (I haven't run the tests, however).
Hope this is useful.
regards,
carlos
Paul Ramsey wrote:
> OK, compiles and runs the XMLTester fine under OS/X 10.4.1
> I'm good to go. Any other test results from other platforms (windows
> anyone? slowaris? freebsd? OS/X 10.3?)
> cvs -d :pserver:cvs at postgis.refractions.net:/home/cvs/postgis co -r
> branch-2-1 geos
> cd geos
> ./autogen.sh
> ./configure
> make
> cd source/text
> ./XMLTester
> Paul
> Paul
> On 6-Jun-05, at 2:07 AM, strk at refractions.net wrote:
>> We'd like to release GEOS 2.1.2, a bugfix and performance
>> improvement work.
>> Changes since 2.1.1:
>> - Segfault fix in Point::isEmpty
>> - Mem Leak fix in OffsetCurveBuilder::getRingCurve
>> - Bugfix in LineSegment::reverse
>> - Added multipolygon buffering test in source/test/testLeaksBig
>> - Ported JTS robustness patch for RobustLineIntersector
>> - Removed useless Coordinate copies in OverlayOp::mergeZ()
>> - Avoided throws by IsValid on invalid input
>> - Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
>> ostringstream
>>   instead of sprintf)
>> - Better support for older compilers (Polygonizer::LineStringAdder
>> friendship)
>> - Removed useless Coordinate copies in CGAlgorithms::isOnLine()
>> - Added support for polygonize and parametrized buffer tests in
>> XMLTester
>> - Fixed support for --includedir and --libdir
>> - Fixed Z interpolation in LineIntersector
>> - Handled NULL results from getCentroid() in XMLTester
>> - Segfault fix in (EMPTY)Geometry::getCentroid()
>> - Made polygon::getBoundary() always OGC-valid (no LinearRings)
>> - Input checking and promoting in
>> GeometryFactory::createMultiLineString()
>> - Segfault fix in GeometryEditor::editPolygon()
>> Did anyone other then me test the code yet ?
>> It is accessible using the branch-2-1 tag of CVS.
>> Any test or bug report is highly appreciated.
>> Thanks
>> --strk;
