[geos-devel] non precision related geometric issue
Carl Anderson carl.anderson at vadose.org
Mon Jun 20 20:02:49 EDT 2005
Based on recent improvements in the geos library, I have started in
depth geometric testing.
Thanks to all for the improvements.
attached is a test file for XMLTester for a failure case.
The B object has an edge intersection with itself, violating assertions
2.1.12.1 and 2.1.12.2 of the SF SQL spec.  GEOS reports it as valid but
upon intersection it abends.  JTS/GEOS is not conditioned to test for
those assertions but Martin may have had those assertions in mind when
writing the overlayOp bts.
This is not a precision issue as can be clearly be seen from the test file.
There is another variation of this issue that I cannot, as of yet,
reliably express with a simple test case.
The variation invloves shared edges between the two test objects.  I
will keep digging.
C.
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20050620/75704668/mytest8.xml
