[geos-devel] ABI protection
strk at refractions.net strk at refractions.net
Sat Jun 25 05:49:28 EDT 2005
Guys, I need C++ gury help here...
We have a big performance improving patch hanging.
This would require adding a new public method to
the Node class.
Now. It sounds to me that this would break ABI, am
I correct in thinking this ?
Someone suggested that adding the method as *last*
item in class definition could avoid this brekage,
setting the new method pointer as last in the vtable,
can we take this as good ?
The problem is that this is probably compiler-specific
so I dunno what to do.
PostGIS itself won't suffer from this as it never
directly uses Nodes, but I think other libs might
(ogr most likely).
If we cannot find a safe way to add a public function
I can still find a workaround using module-static
methods for that, but I'd prefer avoiding it to
keep geos code layout similar between branches.
Comments, tips ?
--strk;
