[geos-devel] patch to make geos compile with gcc 2.95
strk at refractions.net strk at refractions.net
Mon Mar 14 15:10:01 EST 2005
Thanks Bernhard, the code is already present in current CVS, but
commented out..
// This seems to be needed by    GCC 2.95.4
//friend class Polygonizer::LineStringAdder;
I wasn't sure about adding it, if noone sees any problem I'll uncomment.
--strk;
On Mon, Mar 14, 2005 at 08:17:09PM +0100, Bernhard Herzog wrote:
> I've briefly tested geos a bit with postgis.  I needed to make two
> changes to geos-2.1.1.tar.bz2 to get it to compile on my system which
> uses gcc 2.95.4.  One was the stdio include for sprintf which has
> already been reported.
> The other is that at least one of LineStringAdder's methods tries to
> access a private member of Polygonizer.  LineStringAdder is a nested
> class inside of Polygonizer but that doesn't automatically give it
> access to Polygonizer's private members.  The patch below makes
> LineStringAdder a friend of Polygonizer to fix this.  Newer versions of
> gcc apparently allow this kind of access, but gcc 2.95 is correct in
> rejecting it, AFAIK.  Stroustrup 3rd ed. says:
>    C.11.3  Access to Member Class
>    The members of a member class have no special access to members of an
>    enclosing class.
> *** source/headers/geos/opPolygonize.h.~1~	Tue Dec 14 11:35:44 2004
> --- source/headers/geos/opPolygonize.h	Fri Mar 11 14:56:41 2005
> *** 397,402 ****
> --- 397,407 ----
>   		void filter_ro(const Geometry *g){};
> + 	// Make LineStringAdder a fried of Polygonizer so that
> + 	// LineStringAdder's methods can access Polygonizer's private
> + 	// parts.
> + 	friend LineStringAdder;
>   	// default factory
>   	LineStringAdder *lineStringAdder;
>  Bernhard
> Intevation GmbH                                 http://intevation.de/
> Skencil                                           http://skencil.org/
> Thuban                                  http://thuban.intevation.org/
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
