[geos-devel] Precision Howto
Howard Butler hobu at iastate.edu
Tue Sep 20 16:22:17 EDT 2005
All,
I have two "layers" of geometry, set A and set B.  Set A could be described
as the base layer, and is what I would like to compare set B to.  Set B is
actually a bastard child of set A, with some geometries being (exactly) the
same as those in set A, some being edited manually (actual changes), and
some being different due to inconsistent precisions (set B was broken into
many different pieces, edited by many people with many different softwares
and then recombined back into a single layer).
My question is, how can I use the equals() test and PrecisionModels to weed
out the truly equal and the "equal except different by some tolerance" from
the "truly different and edited by human hands"?  Is it possible to say
with GEOS, "these two geometries are equal if all of their vertices are
within 2.0 meters"?  If so, how?
Howard
PS, I'm using the Python SWIG bindings, which emit pretty much the whole
C++ API, but could be convinced to move to C++ if it is deemed necessary.
