[geos-devel] WKBReader bug fix, C-API updates
strk at refractions.net strk at refractions.net
Tue Sep 27 12:36:15 EDT 2005
I've fixed a bug in the WKBReader code prematurely
destroying the GeometryFactory used in output construction.
The interface has also been reduced to *require* a GeometryFactory
reference in input.
The C-API now contains version informations (see the geos_c.h file)
and a new function to construct Collection from array of Geometries.
I've been testing the C-API by implementing a postgis interface
to it, and it seems to be working fine.
--strk;
