[geos-devel] Geos 2.2.2 SWIG patches/updates
Charlie Savage cfis at interserv.com
Mon Apr 3 15:26:16 EDT 2006
Hi everyone,
Over the weekend I sent a patch to Strk for the Geos 2.2.2 SWIG
bindings.  It basically back ports the work I've done on GEOS head.
I've included the updated geos.i below for people who are interested in
reviewing it.
What the patch does:
* Updates memory handling, you can now run the equivalent of example.cpp
in python / ruby without causing segmentation faults
* Updates methods like WKBReader.read so that they return the
appropriate geometry type (point, line, etc.) as opposed to
Geos::Geometry.
* Limits the exposed api.  Only exposes geom.h, version.h, util.h, io.h
* Exposes WKBReader.read/write and WKTReader.read/write and
WKBWriter.read/write and WKTWriter.read/write which were not previously
available from scripting languages
* Adds Ruby support, with test cases
So from a scripting standpoint the bindings expose more functionality
and should me more stable.  There are two API changes:
* Instead of geometry.getSRID()/setSRID() you can now do geometer.srid
* Instead of coordinate.getX()/getY() you can now do coordinate.x
I made those changes since it seemed a much more natural way of working
with the bindings.  However, if this causes issues on the Python side I
will move them just to he Ruby bindings - its literally cut/paste 4
lines of SWIG code.
Comments/feedback welcome.
Thanks,
Charlie
Index: swig/geos.i
RCS file: /home/cvs/postgis/geos/swig/geos.i,v
retrieving revision 1.3
diff -u -r1.3 geos.i
--- swig/geos.i	26 Jul 2004 18:53:38 -0000	1.3
+++ swig/geos.i	2 Apr 2006 23:56:41 -0000
@@ -4,8 +4,10 @@
   * geos.i
   * Copyright 2004 Sean Gillies, sgillies at frii.com
+ * Updated 2005 Charlie Savage, cfis at interserv.coma
- * Interface for a SWIG generated geos module.
+ * Interface for a SWIG generated geos module.  Depends on
+ * SWIG 1.3.29 and higher.
   * This is free software; you can redistribute and/or modify it under
   * the terms of the GNU Lesser General Public Licence as published
@@ -13,33 +15,311 @@
   * See the COPYING file for more information.
  %module geos
-%include "std_string.i"
  %include "exception.i"
+%include "std_string.i"
+%include "std_vector.i"
+%include "std_except.i"
+%include "factory.i"
-#include "../../source/headers/geos.h"
+#include "geos.h"
+#include "geos/version.h"
+#include "geos/planargraph.h"
+#include "geos/opLinemerge.h"
+#include "geos/opPolygonize.h"
+#include <sstream>
-// Following methods are prototypes but unimplemented and are to be ignored
-%ignore geos::MultiPoint::isClosed;
+/* ================= Shadowed Methods ============== */
+/* The overloaded C++ methods cannot be disambiguated by
+   SWIG.  For example:
+	geos::GeometryFactory::createPoint(CoordinateSequence *) const;
+	geos::GeometryFactory::createPoint(const CoordinateSequence&) const;
+   For each pair of methods, one will take ownership
+   of the parameter (thus it is passed as a pointer) while
+   the other one will not (thus is passed as a const reference).
+   To be on the safe-side, we tell SWIG to ignore the method
+   that takes over ownership.  To expose these ignored methods
+   to a scripting language requires renaming the method to
+   something else.  This can be done in each language module
+   as it is loaded below.*/
+%ignore geos::GeometryFactory::buildGeometry(vector<Geometry * > *) const;
+%ignore geos::GeometryFactory::createGeometryCollection(vector<Geometry
* > *) const;
+%ignore geos::GeometryFactory::createLinearRing(CoordinateSequence *)
const;
+%ignore geos::GeometryFactory::createLineString(CoordinateSequence *)
const;
+%ignore geos::GeometryFactory::createMultiLineString(vector<Geometry *
 > *) const;
+%ignore geos::GeometryFactory::createMultiPoint(vector<Geometry * > *)
const;
+%ignore geos::GeometryFactory::createMultiPolygon(vector<Geometry * >
*) const;
+%ignore geos::GeometryFactory::createPoint(CoordinateSequence *) const;
+%ignore geos::GeometryFactory::createPolygon(LinearRing
*,vector<Geometry * > *) const;
+/* For scripting languages the CoordinateSequence::add method is ambigious
+   since there are two overloaded versions that are the same except
+   a const declaration.  However, one of them is available only for
+   backwards compatibility so hide that one.*/
+%ignore geos::CoordinateSequence::add(CoordinateSequence *cl,bool
allowRepeated,bool direction);
+/* ================= Typemaps ============== */
+/* These typemaps allows scripting languages to call methods that take
+   iostreams and ostreams, such as WKTWriter.printHEX and WKBWriter.write.
+   The results are returned from the method as a string object in the
+   scripting language.*/
+/* Get rid of the ostream parameter by setting numinputs to 0 */
+%typemap(in,numinputs=0) ostream& (std::ostringstream stream)
+  $1 = &stream;
+/* Return the results as a string object in the scripting language */
+%typemap(argout) ostream&
+	std::string str = stream$argnum.str();
+	$result = SWIG_FromCharPtrAndSize(str.data(), str.size());
+/* This typemap allows the scripting language to pass in a string
+   which will be converted to an istringstream for GEOS */
+%typemap(in) istream& (char *buf = 0, size_t size = 0, int alloc = 0,
std::stringstream stream)
+  /* Convert from scripting language string to char* */
+  if (SWIG_AsCharPtrAndSize($input, &buf, &size, &alloc) != SWIG_OK)
+    %argument_fail(SWIG_TypeError, "(TYPEMAP, SIZE)", $symname, $argnum);
+  /* Write data to the stream.  Note that the returned size includes
+     the last character, which is a null character.  We do not want
+     to write that to the stream so subtract one from its size. */
+  stream.write(buf, size - 1);
+  $1 = &stream;
+/* Free allocated buffer created in the (in) typemap */
+%typemap(freearg) istream&
+  if (alloc$argnum == SWIG_NEWOBJ) %delete_array(buf$argnum);
+/* ==============  Language Specific Files ============ */
+/* Import language specific SWIG files.  This allows each language
+   to define its own renames as well as any special functionality
+   such as language specific iterators for collections. Note
+   that %include allows the included files to generate interface
+   wrapper code while %import does not.  Thus use %include since
+   this is an important feature (for example, Ruby needs it to #undef
+   the select macro) */
+#ifdef SWIGPYTHON
+%include ../python/python.i
+#endif
+#ifdef SWIGRUBY
+%include ../ruby/ruby.i
+#endif
+/* ================= Ownership Rules ============== */
-// Required renaming
-%rename(Coordinate_Coordinate) Coordinate::Coordinate;
+/* These disown definitions are not correct in all cases -
+   needs to be fixed */
+%apply SWIGTYPE *DISOWN { geos::CoordinateSequence * };
+%apply SWIGTYPE *DISOWN { geos::LinearRing * };
+%apply SWIGTYPE *DISOWN { std::vector<geos::Geometry * > * };
+%apply SWIGTYPE *DISOWN { std::vector<geos::Coordinate> * };
+// These methods create new objects
+namespace geos {
+%newobject *::clone;
+%newobject *::getCoordinates;
+%newobject CoordinateArraySequence::create;
+%newobject GeometryFactory::createPointFromInternalCoord;
+%newobject GeometryFactory::toGeometry;
+%newobject GeometryFactory::createPoint;
+%newobject GeometryFactory::createGeometryCollection;
+%newobject GeometryFactory::createMultiLineString;
+%newobject GeometryFactory::createMultiPolygon;
+%newobject GeometryFactory::createLinearRing;
+%newobject GeometryFactory::createMultiPoint;
+%newobject GeometryFactory::createPolygon;
+%newobject GeometryFactory::createLineString;
+%newobject GeometryFactory::buildGeometry;
+%newobject GeometryFactory::createGeometry;
+%newobject GeometricShapeFactory::getEnvelope;
+%newobject WKBReader::read;
+%newobject WKBReader::readHEX;
+%newobject WKTReader::read;
+/* Surface methods that return Geometry* so that they
+	 return the actual geometry object (point, linestring, etc.)
+	 instead of a generic geometry object.  Make sure the checks
+	 go from child class to parent class so we get the right one.*/
+%factory(geos::Geometry * geos::WKTReader::read, geos::Point,
+				 geos::LinearRing, geos::LineString,
+				 geos::Polygon,
+				 geos::MultiPoint, geos::MultiLineString,
+				 geos::MultiPolygon, geos::GeometryCollection);
+%factory(geos::Geometry * geos::WKBReader::read, geos::Point,
+				 geos::Polygon,
+%factory(geos::Geometry * geos::WKBReader::readHEX, geos::Point,
+				 geos::Polygon,
+%factory(geos::Geometry * geos::Geometry::downcast, geos::Point,
+				 geos::Polygon,
+%newobject geos::Geometry::fromWKT;
+%factory(geos::Geometry * geos::Geometry::fromWKT, geos::Point,
+				 geos::Polygon,
+%newobject geos::Geometry::fromHEX;
+%factory(geos::Geometry * geos::Geometry::fromHEX, geos::Point,
+				 geos::Polygon,
+/* ================= Operators  ============== */
+/* Ignore these for now - if we don't SWIG will create
+   names with the same methods, which doesn't work out very well.
+	 std::ostream& operator<<(std::ostream& os, const planarNode& n);
+   std::ostream& operator<<(std::ostream& os, const planarEdge& n);
+   std::ostream& operator<< (std::ostream& os, const Coordinate& c);
+   std::ostream& operator<< (std::ostream& o, const LineSegment& l);
+   std::ostream& operator<< (std::ostream& os, const Coordinate& c); */
+%ignore geos::operator<<;
+/* ================= Exception Handling  ============== */
+/* Mark these classes as exception classes */
+%exceptionclass geos::GEOSException;
+/* These are all subclasses of GEOSException */
+%exceptionclass geos::AssertionFailedException;
+%exceptionclass geos::IllegalArgumentException;
+%exceptionclass geos::ParseException;
+%exceptionclass geos::TopologyException;
+%exceptionclass geos::UnsupportedOperationException;
+/* This exception class is not surfaced to SWIG
+%exceptionclass geos::NotRepresentableException;*/
+/* Setup up generalized exception handling.  Note that GEOS
+   2 series throws classes that are allocated on the heap
+	 so we need to catch them by pointer and are responsible
+	 for freeing them.  To do this we'll just pass the object
+	 along the scripting language (wrapped of course) and make
+	 it responsbile for freeing the object via the
+   use of the SWIG_POINTER_OWN flag.*/
  %exception {
      try {
          $action
+  catch (geos::AssertionFailedException *e) {
+			%raise(SWIG_NewPointerObj(e,
SWIGTYPE_p_geos__AssertionFailedException, SWIG_POINTER_OWN),
"geos::AssertionFailedException",
SWIGTYPE_p_geos__AssertionFailedException);
+  catch (geos::IllegalArgumentException *e) {
SWIGTYPE_p_geos__IllegalArgumentException, SWIG_POINTER_OWN),
"geos::IllegalArgumentException",
SWIGTYPE_p_geos__IllegalArgumentException);
+  catch (geos::ParseException *e) {
+			%raise(SWIG_NewPointerObj(e, SWIGTYPE_p_geos__ParseException,
SWIG_POINTER_OWN), "geos::ParseException", SWIGTYPE_p_geos__ParseException);
+  catch (geos::TopologyException *e) {
+			%raise(SWIG_NewPointerObj(e, SWIGTYPE_p_geos__TopologyException,
SWIG_POINTER_OWN), "geos::TopologyException",
SWIGTYPE_p_geos__TopologyException);
+  catch (geos::UnsupportedOperationException *e) {
SWIGTYPE_p_geos__UnsupportedOperationException, SWIG_POINTER_OWN),
"geos::UnsupportedOperationException",
SWIGTYPE_p_geos__UnsupportedOperationException);
      catch (geos::GEOSException *e) {
-        SWIG_exception(SWIG_RuntimeError, e->toString().data());
+			%raise(SWIG_NewPointerObj(e, SWIGTYPE_p_geos__GEOSException,
SWIG_POINTER_OWN), "geos::GEOSException", SWIGTYPE_p_geos__GEOSException);
+  catch (...) {
+      SWIG_exception(SWIG_RuntimeError, "Unknown exception took place
in the method: $symname.");
-// Now include the headers to be wrapped
+/* =============  Define Attributes ============ */
+%include <attribute.i>
+%attribute(geos::Point, double, x, getX);
+%attribute(geos::Point, double, y, getY);
+%attribute(geos::Geometry, double, srid, getSRID, setSRID);
+/* ===========  Headers To Wrap  ================ */
  %include "../../source/headers/geos/geom.h"
+%include "../../source/headers/geos/version.h"
  %include "../../source/headers/geos/util.h"
  %include "../../source/headers/geos/io.h"
+/* ===========  Global Factory  ================ */
+/* When creating geometries GEOS needs to use a factory.
+   The created geometries have back references to the
+	 factory and thus the factory should not be deleted.
+	 However, this becomes hard when unmarshalling serialized
+	 objects.  So create a global factory.*/
+/* Add some helper methods to geometries */
+%extend geos::Geometry {
+	static geos::GeometryFactory& factory()
+		static geos::GeometryFactory factory;
+		return factory;
+	static geos::WKBReader& reader()
+		#if GEOS_VERSION_MAJOR == 2
+		static geos::WKBReader reader(geos_Geometry_factory());
+		#else
+		static geos::io::WKBReader reader(geos_Geometry_factory());
+		#endif
+		return reader;
+	static Geometry* fromWKT(std::string wkt)
+		std::stringstream in(wkt);
+		return geos_Geometry_reader().read(in);
+	static Geometry* fromHEX(std::string hex)
+		std::stringstream in(hex);
+		return geos_Geometry_reader().readHEX(in);
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060403/d5bfdd85/smime.bin
