[geos-devel] 3.0?
strk at refractions.net strk at refractions.net
Thu Aug 3 12:34:16 EDT 2006
I'm actually just waiting for Charlies fixes on the SWIG binding
(make dist rule must work, even if that means postponing automatic
build of the wrappers).
About the bug items, the only important one seems to be #109
(Byte order not processed correctly) which should be fixed
in the HEAD branch.
Unit testing addition can be an incremental task (we have survived
w/out them for a long long time now :)
--strk;
On Thu, Aug 03, 2006 at 06:15:09PM +0200, Mateusz Loskot wrote:
> Paul Ramsey wrote:
> > What are the remaining tasks on getting 3.0 out the door? I'd like it
> > out sooner than later, it has the changes from the JTS 1.7 synch sitting
> > there, and people could get some use out of those if we'd just drop a
> > numbered release!  We'll roll the next client's updates into a 3.0.1 or
> > 3.1.0.
> Certainly, I'm not able to answer your question, but I don't think (i've
> not heard from strk) that missing Unit Tests can defer 3.0 release.
> There is plenty of work to do to finish Unit Tests, but AFAIK it's
> highly recommended, not mandatory.
> There are 6 bugs on the bug tracker (4 of them seem to be important).
> So, I hope there are no reason to release GEOS 3.0.
