[geos-devel] SVN - Line Feeds
Charlie Savage cfis at savagexi.com
Thu Aug 3 18:26:50 EDT 2006
Okay, this is what I've done.  I removed the eol line style from
configure.in, then forced line feeds to be LF.
That fixes the problems on MingW/msys and Linux (well there was no
problem there).  Don't know about the Mac though, doesn't it use CR?
Charlie
Paul Ramsey wrote:
> As long as non-mingw windows compiles don't get screwed by having unix
> linefeeds...
> Charlie Savage wrote:
>> Okay, I've tracked down an issue caused by the move to SVN.
>> By default, SVN does not convert line feeds based on platform, unlike
>> CVS.  However, you can override this either by local setting on your
>> machine or by adding a property to each file.  For more information see:
>> http://svnbook.red-bean.com/en/1.0/ch07s02.html#svn-ch-7-sect-2.3.5
>> It looks like in the automated move to SVN, every file was tagged with
>> svn:eol-style native.
>> So, on Windows, you get CR/LF while on *Nix its just Line Feed.  Thus
>> configure.in gets CR/LF which breaks autoconf on line 297 when
>> compiling under MingW.
>> It seems to me the best solution is to remove this property on every
>> file so code checks out the same on every system.  Alternatively, I
>> can play with .configure.in to see if I can get it to work on both
>> platforms (since everything else seems to at least compile).
>> What should I do?
>> Charlie
>> strk at refractions.net wrote:
>>> On Thu, Aug 03, 2006 at 12:11:40PM -0600, Charlie Savage wrote:
>>>> For GEOS 3 it would be really good to support mingw.  I have not
>>>> been able to compile the geos 3 head branch using migw for a long
>>>> time - I get a series of linker errors that I posted to the last
>>>> about a month ago.  Any help fixing them would be appreciated.
>>>> Anyway, just tried again after the move to SVN.  And this time I
>>>> can't get past autogen didn't work.
>>>> $ ./autogen.sh
>>>> Running autoheader
>>>> ' is already registered with AC_CONFIG_FILES.
>>>> autoconf/status.m4:848: AC_CONFIG_FILES is expanded from...
>>>> configure.in:297:
>>> Could you try the version in CVS ? (just in case it's CR/NL issue).
>>> --strk;
>>> geos-devel mailing list
>>> geos-devel at geos.refractions.net
>>> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060803/d5026d1d/smime.bin
