[geos-devel] 3.0?
Charlie Savage cfis at savagexi.com
Fri Aug 4 19:20:49 EDT 2006
Okay, I've looked at this a bit more and don't see any obvious problems.
    I did a clean checkout and compiled normally (./configure, make).
In the generated make files I see:
CXXFLAGS = -g -O2 -DGEOS_INLINE -Wall -ansi -pedantic -Wno-long-long
However, it looks like the *.inl files are being included twice.
Suggestions?
Charlie
Charlie Savage wrote:
>> Anything else missing before releasing 3.0.0rc1 ?
> I'd like to see MingW work.
> I fixed up a autoconf issue (the line feed one) and checked in a couple
> changes yesterday so geos would compile.
> However, it doesn't link (errors below).  I'll try to investigate
> further this weekend.  Other than that, I'm happy.
> Charlie
> .libs/libgeos.lax/libalgorithm.a/MCPointInRing.o: In function
> `ZN4geos9algorithm13MCPointInRing10MCSelecterD1Ev':C:/Development/msys/src/geos/trunk/source/algorithm/../../source/headers/geos/algorithm/PointInRing.h:(.text$_ZN4geos4geom11LineSegmentD1Ev[__ZN4geos4geom11LineSegmentD1Ev]+0x0):
> multiple definition of `geos::geom::LineSegment::~LineSegment()'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/geom/LineSegment.inl:51:
> first defined here
> `ZN4geos9algorithm13MCPointInRing10MCSelecterD1Ev':C:/Development/msys/src/geos/trunk/source/algorithm/../../source/headers/geos/algorithm/PointInRing.h:(.text$_ZN4geos4geom11LineSegmentD0Ev[__ZN4geos4geom11LineSegmentD0Ev]+0x0):
> first defined here
> .libs/libgeos.lax/libalgorithm.a/PointLocator.o: In function
> `ZNSt8_Rb_treeIPKN4geos4geom10LineStringESt4pairIKS4_PNS0_9geomgraph4EdgeEESt10_Select1stISA_ESt4lessIS4_ESaISA_EE8_M_eraseEPSt13_Rb_tree_nodeISA_E':C:/Development/msys/src/geos/trunk/source/algorithm/PointLocator.cpp:(.text$_ZN4geos9geomgraph13GeometryGraphD0Ev[__ZN4geos9geomgraph13GeometryGraphD0Ev]+0x0):
> multiple definition of `geos::geomgraph::GeometryGraph::~GeometryGraph()'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/geomgraph/GeometryGraph.inl:46:
> first defined here
> `ZNSt8_Rb_treeIPKN4geos4geom10LineStringESt4pairIKS4_PNS0_9geomgraph4EdgeEESt10_Select1stISA_ESt4lessIS4_ESaISA_EE8_M_eraseEPSt13_Rb_tree_nodeISA_E':C:/Development/msys/src/geos/trunk/source/algorithm/PointLocator.cpp:(.text$_ZN4geos9geomgraph13GeometryGraphD1Ev[__ZN4geos9geomgraph13GeometryGraphD1Ev]+0x0):
> first defined here
> .libs/libgeos.lax/libgeom.a/CoordinateArraySequenceFactory.o: In
> function
> `ZN4geos4geom30CoordinateArraySequenceFactoryD0Ev':C:/Development/msys/src/geos/trunk/source/geom/CoordinateArraySequenceFactory.cpp:27:
> `geos::geom::CoordinateArraySequenceFactory::create(std::vector<geos::geom::Coordinate,
> std::allocator<geos::geom::Coordinate> >*) const'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/geom/CoordinateArraySequenceFactory.inl:28:
> first defined here
> function
> `geos::geom::CoordinateArraySequenceFactory::create(unsigned int,
> unsigned int) const'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/geom/CoordinateArraySequenceFactory.inl:42:
> first defined here
> .libs/libgeos.lax/libgeom.a/MultiLineString.o: In function
> `ZNSt8_Rb_treeIPKN4geos4geom10LineStringESt4pairIKS4_PNS0_9geomgraph4EdgeEESt10_Select1stISA_ESt4lessIS4_ESaISA_EE8_M_eraseEPSt13_Rb_tree_nodeISA_E':c:/Development/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/bits/stl_vector.h:(.text$_ZNK4geos4geom15MultiLineString5cloneEv[__ZNK4geos4geom15MultiLineString5cloneEv]+0x0):
> multiple definition of `geos::geom::MultiLineString::clone() const'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/geom/MultiLineString.inl:36:
> first defined here
> .libs/libgeos.lax/libgeom.a/MultiPolygon.o: In function
> `ZNSt6vectorIPN4geos4geom8GeometryESaIS3_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS3_S5_EERKS3_':c:/Development/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/ext/new_allocator.h:(.text$_ZNK4geos4geom12MultiPolygon5cloneEv[__ZNK4geos4geom12MultiPolygon5cloneEv]+0x0):
> multiple definition of `geos::geom::MultiPolygon::clone() const'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/geom/MultiPolygon.inl:34:
> first defined here
> .libs/libgeos.lax/libio.a/WKBReader.o: In function
> `ZSt6fill_nIPPN4geos4geom8GeometryEjS3_ET_S5_T0_RKT1_':C:/Development/msys/src/geos/trunk/source/io/WKBReader.cpp:(.text$_ZN4geos2io21ByteOrderDataInStream7readIntEv[__ZN4geos2io21ByteOrderDataInStream7readIntEv]+0x0):
> multiple definition of `geos::io::ByteOrderDataInStream::readInt()'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/io/ByteOrderDataInStream.inl:66:
> first defined here
> .libs/libgeos.lax/libnoding.a/MCIndexNoder.o: In function
> `ZNSt6vectorIPN4geos5index5chain13MonotoneChainESaIS4_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS4_S6_EERKS4_':C:/Development/msys/src/geos/trunk/source/noding/MCIndexNoder.cpp:(.text$_ZNK4geos6noding12MCIndexNoder18getNodedSubstringsEv[__ZNK4geos6noding12MCIndexNoder18getNodedSubstringsEv]+0x0):
> multiple definition of `geos::noding::MCIndexNoder::getNodedSubstrings()
> const'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/noding/MCIndexNoder.inl:35:
> first defined here
> .libs/libgeos.lax/libnoding.a/MCIndexSnapRounder.o: In function
> `ZN4geos6noding9snapround18MCIndexSnapRounderD1Ev':C:/Development/msys/src/geos/trunk/source/noding/snapround/MCIndexSnapRounder.cpp:(.text$_ZNK4geos6noding9snapround18MCIndexSnapRounder18getNodedSubstringsEv[__ZNK4geos6noding9snapround18MCIndexSnapRounder18getNodedSubstringsEv]+0x0):
> `geos::noding::snapround::MCIndexSnapRounder::getNodedSubstrings() const'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/noding/snapround/MCIndexSnapRounder.inl:32:
> first defined here
> .libs/libgeos.lax/liboperation.a/ConnectedInteriorTester.o: In function
> `ZNSt6vectorIPN4geos9geomgraph8EdgeRingESaIS3_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS3_S5_EERKS3_':c:/Development/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/bits/vector.tcc:(.text$_ZN4geos9operation7overlay15MinimalEdgeRing11setEdgeRingEPNS_9geomgraph12DirectedEdgeEPNS3_8EdgeRingE[__ZN4geos9operation7overlay15MinimalEdgeRing11setEdgeRingEPNS_9geomgraph12DirectedEdgeEPNS3_8EdgeRingE]+0x0):
> `geos::operation::overlay::MinimalEdgeRing::setEdgeRing(geos::geomgraph::DirectedEdge*,
> geos::geomgraph::EdgeRing*)'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/operation/overlay/MinimalEdgeRing.inl:31:
> first defined here
> `ZNSt6vectorIPN4geos9geomgraph8EdgeRingESaIS3_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS3_S5_EERKS3_':c:/Development/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/bits/vector.tcc:(.text$_ZN4geos9operation7overlay15MinimalEdgeRing7getNextEPNS_9geomgraph12DirectedEdgeE[__ZN4geos9operation7overlay15MinimalEdgeRing7getNextEPNS_9geomgraph12DirectedEdgeE]+0x0):
> `geos::operation::overlay::MinimalEdgeRing::getNext(geos::geomgraph::DirectedEdge*)'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/operation/overlay/MinimalEdgeRing.inl:37:
> first defined here
> `ZNSt6vectorIPN4geos9geomgraph8EdgeRingESaIS3_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS3_S5_EERKS3_':c:/Development/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/bits/vector.tcc:(.text$_ZN4geos9operation7overlay15MinimalEdgeRingD1Ev[__ZN4geos9operation7overlay15MinimalEdgeRingD1Ev]+0x0):
> `geos::operation::overlay::MinimalEdgeRing::~MinimalEdgeRing()'
> .libs/inlines.o:C:/Development/msys/src/geos/trunk/source/../source/headers/geos/operation/overlay/MinimalEdgeRing.inl:43:
> first defined here
> `ZNSt6vectorIPN4geos9geomgraph8EdgeRingESaIS3_EE13_M_insert_auxEN9__gnu_cxx17__normal_iteratorIPS3_S5_EERKS3_':c:/Development/MinGW/bin/../lib/gcc/mingw32/3.4.5/../../../../include/c++/3.4.5/bits/vector.tcc:(.text$_ZN4geos9operation7overlay15MinimalEdgeRingD0Ev[__ZN4geos9operation7overlay15MinimalEdgeRingD0Ev]+0x0):
> first defined here
> make[2]: *** [libgeos.la] Error 1
> make[1]: *** [all-recursive] Error 1
> make: *** [all-recursive] Error 1
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060804/78a7dae3/smime.bin
