[geos-devel] GEOS and VC++ 2005
Charlie Savage cfis at interserv.com
Sat Jan 7 19:09:20 EST 2006
Hi everyone,
I'm trying to compile GEOS HEAD using Visual C++ 2005.  I had to patch a
couple files, which I explain below (patch is also attached below).
There is however a more fundamental issue which is setting up the right
exports for libgeos.dll.  This is generally done via
dllexport/dllimport, just like in libgeos_c.  Since libgeos.dll exports
C++ classes, you can dllexport all the classes.  Of course any such
exported classes can only be used by code compiled by VC++ due to C++
name mangling.  The same if also true if you are using any other
compiler, for example MingW, to build libgeos.dll - it can only be
linked against by MinGW.
Anyway, there are few solutions.  First, do nothing and disallow the
creation of dlls using VC++ (you could build static libraries instead).
Second, add the right dllExport/dllImport macros to the class
definitions.  Third, and what I did, manually construct a def file by
using information extracted from the dll by dumpbin or the VC++ /MAP
option.  The third option isn't very good because it is manually
intensive and fairly brittle - although I suppose you could automate it
using a fair bit of scripting magic.
Anyway, being able to build geos with VC++ is useful, because it makes
it easier to build extensions for Ruby and Python, both of which are
compiled using VC++ on Windows.
Just my two cents.
Thanks,
Charlie
The following patches are needed to build GEOS with Visual Studio C++
2005.  I've tested them against both VC++ and MinGW on Windows.  Note I
have also created updated Visual Studio C++  if anyone is interested
(the old that was removed from CVS no longer works).
1.  The main issue is from geomgraph.h, lines 490 and 491:
    EdgeIntersectionListIterator begin() const { return nodeMap.begin(); }
    EdgeIntersectionListIterator end() const { return nodeMap.end(); }
Where:
typedef set<EdgeIntersection *, EdgeIntersectionLessThen>::iterator
EdgeIntersectionListIterator;
VC++ does not compile this because it complains that a non-const
iterator is being returned from a function that is marked const.  It
seems to me that VC++ is correct, and this should not be allowed.  The
fix is easy enough, return an const_iterator (which I called
EdgeIntersectionListIterator Const) instead of a iterator.  This then
effects a couple of places in the code.
2.  geos_c.cpp, line 1570.
return (finite(az) && az != DoubleNotANumber);
There is not a finite function, but there is a FINITE macro.  So I
switched to the macro.
3.  GeometricShapeFactory, line 202
    if (angSize <= 0.0 || angSize > 2 * M_PI) //3.14159265358979
M_PI does not seem defined on Windows, so I defined it at the top of the
file.
Thanks,
Charlie
Index: source/geomgraph/EdgeIntersectionList.cpp
RCS file: /home/cvs/postgis/geos/source/geomgraph/EdgeIntersectionList.cpp,v
retrieving revision 1.16
diff -u -r1.16 EdgeIntersectionList.cpp
--- source/geomgraph/EdgeIntersectionList.cpp    8 Dec 2005 01:11:29
-0000    1.16
+++ source/geomgraph/EdgeIntersectionList.cpp    7 Jan 2006 23:48:53 -0000
@@ -65,7 +65,7 @@
 bool
 EdgeIntersectionList::isIntersection(const Coordinate& pt) const
-    EdgeIntersectionListIterator it=nodeMap.begin(), endIt=nodeMap.end();
+    EdgeIntersectionListIteratorConst it=nodeMap.begin(),
     for (; it!=endIt; ++it)
         EdgeIntersection *ei=*it;
@@ -158,7 +158,7 @@
 EdgeIntersectionList::print() const
     string out="Intersections: ";
-    EdgeIntersectionListIterator it=begin(), endIt=end();
+    EdgeIntersectionListIteratorConst it=begin(), endIt=end();
     for (; it!=endIt; ++it) {
         out+=ei->print();
Index: source/util/GeometricShapeFactory.cpp
RCS file: /home/cvs/postgis/geos/source/util/GeometricShapeFactory.cpp,v
retrieving revision 1.8
diff -u -r1.8 GeometricShapeFactory.cpp
--- source/util/GeometricShapeFactory.cpp    8 Dec 2004 13:54:44
-0000    1.8
+++ source/util/GeometricShapeFactory.cpp    7 Jan 2006 23:48:53 -0000
@@ -17,6 +17,10 @@
 #include <geos/util.h>
 #include <stdio.h>
+#ifndef M_PI
+#define M_PI        3.14159265358979323846
+#endif
 namespace geos {
Index: source/headers/geos/geomgraph.h
RCS file: /home/cvs/postgis/geos/source/headers/geos/geomgraph.h,v
retrieving revision 1.26
diff -u -r1.26 geomgraph.h
--- source/headers/geos/geomgraph.h    7 Dec 2005 19:18:23 -0000    1.26
+++ source/headers/geos/geomgraph.h    7 Jan 2006 23:48:53 -0000
@@ -464,6 +464,7 @@
+typedef set<EdgeIntersection *,
EdgeIntersectionLessThen>::const_iterator EdgeIntersectionListIteratorConst;
  * A list of edge intersections along an Edge.
@@ -486,8 +487,8 @@
     EdgeIntersectionListIterator begin() { return nodeMap.begin(); }
     EdgeIntersectionListIterator end() { return nodeMap.end(); }
-    EdgeIntersectionListIterator begin() const { return nodeMap.begin(); }
-    EdgeIntersectionListIterator end() const { return nodeMap.end(); }
+    EdgeIntersectionListIteratorConst begin() const { return
nodeMap.begin(); }
+    EdgeIntersectionListIteratorConst end() const { return nodeMap.end(); }
     bool isEmpty() const;
     bool isIntersection(const Coordinate& pt) const;
Index: source/capi/geos_c.cpp
RCS file: /home/cvs/postgis/geos/source/capi/geos_c.cpp,v
retrieving revision 1.19
diff -u -r1.19 geos_c.cpp
--- source/capi/geos_c.cpp    13 Dec 2005 23:03:25 -0000    1.19
+++ source/capi/geos_c.cpp    7 Jan 2006 23:48:53 -0000
@@ -1567,7 +1567,7 @@
     double az = g->getCoordinate()->z;
     //sprintf(msg, "ZCoord: %g", az);
     //ERROR_MESSAGE(msg);
-    return (finite(az) && az != DoubleNotANumber);
+    return (FINITE(az) && az != DoubleNotANumber);
 int
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060107/45ae6bc0/smime.bin
