[geos-devel] geos-2.2.0 / FreeBSD 4
strk at refractions.net strk at refractions.net
Mon Jan 9 06:17:00 EST 2006
>From the INSTALL file in GEOS toplevel dir:
Compatibility notes
GCC 2.95.2 seems to lack the 'sstream' header file required
to build GEOS. GCC 2.96 is known to work.
--strk;
On Mon, Jan 09, 2006 at 12:05:48PM +0100, Benjamin Thelen wrote:
> Hello,
> Ups, sorry, my fault. I've been so busy with this, that I mistakenly
> assumed that you of course know what I'm talking about :-). Sorry.
> Building geos-2.2.1 fails on FreeBSD 4.11 (gcc-2.95) with this error:
>  g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> -I../../source/headers/geos -I../../source/headers -DGEOS_VERSION=2.2.1
> -g -O2 -c ../io/WKBReader.cpp -Wp,-MD,.deps/WKBReader.TPlo  -fPIC -DPIC
> -o .libs/WKBReader.o
> ../io/WKBReader.cpp: In function `static class ostream &
> geos::WKBReader::printHEX(istream &, ostream &)':
> ../io/WKBReader.cpp:27: syntax error before `::'
> ../io/WKBReader.cpp:46: `fl' undeclared (first use this function)
> ../io/WKBReader.cpp:46: (Each undeclared identifier is reported only once
> ../io/WKBReader.cpp:46: for each function it appears in.)
> gmake[2]: *** [WKBReader.lo] Error 1
> gmake[2]: Leaving directory `/data/src/geos-2.2.1/source/geom'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory `/data/src/geos-2.2.1/source'
> gmake: *** [all-recursive] Error 1
> If you need to have more information, please let me know!
> Any idea?
> Kind Regards,
> Ben
> strk at refractions.net schrieb:
> >If you are more specific on what's wrong we *might* help.
> >--strk;
> >On Fri, Dec 23, 2005 at 08:52:55AM +0100, Benjamin Thelen wrote:
> >>Hello list,
> >>I've just subscribed to the geos-devel list in order to ask what it's
> >>about geos > 2.1.4 (which succesfully builds on FreeBSD4) on FreeBSD4
> >>and saw that the responsible FreeBSD portmaintainer has already been
> >>asking there. But to be honest, I did't get the conclusion, whether you
> >>or he is working on a solution or whether there already is a solution or
> >>whether there is just no.
> >>I've just tried to build 2.2.0, 2.2.1 using gcc-3.4, but without success.
> >>What's the status, will there be a solution or a workaround? This would
> >>really be great! I'd really appreciate any information.
> >>Thanks,
> >>Ben
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
