[geos-devel] CAPI versioning and branches
Mateusz Loskot mateusz at loskot.net
Fri Jul 7 16:07:25 EDT 2006
strk at refractions.net wrote:
> Moving toward releases 2.2.3 and 3.0.0 I've been thinking
> we'll have problem with CAPI lib versioning.
> Problem is we need to make sure CAPI from 2.2 branch
> is less- versioned then from HEAD. The only solution
> that comes to my mind is incrementing the minor number
> in HEAD, even if there is no change at all (well, there
> is a micro change in this case, but as a generally rule).
> So, 2.2.3 would come out with CAPI 1.1.1 and 3.0.0 with
> CAPI 1.2.0. SONAME should always be set to libgeos_so.1
> so that minor increments won't be binary-incompatible.
> How does it sound ?
Yes, it does for me.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
