[geos-devel] equalsExact
Charlie Savage cfis at savagexi.com
Mon Jul 10 20:06:40 EDT 2006
I noticed the c api exposes the equals method on geometry but not
equalExact.  The equals method is a topological comparison while the
equalsExact compares geometries node by node (you can specify a
tolerance for the comparison)..
I find equalsExact useful when writing tests cases (for example, geom1
-> wkb -> geom2, then geom1.equalsExact(geom2)).
I was wondering if this is more generally useful and should be exposed
as part the c api?
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060710/f8fe1688/smime.bin
