[geos-devel] Re: [postgis-devel] Re: CVS to SVN move
Paul Ramsey pramsey at refractions.net
Wed Jul 26 15:54:04 EDT 2006
That said, option 2 is fine with me. If we find we are getting
conflicts, we can always back out to option 1 later.
P
Paul Ramsey wrote:
> The usual issues apply to putting generated files into the repository:
> if different people with different swigs generate these files they will
> potentially clobber each other in the repository and even generate
> conflicts.
> A checks out
> B checks out
> A generates and updates and commits
> B generates and updates, conflict!
> P
> Charlie Savage wrote:
>> Hmm...Looks like goes.py is not in SVN (probably wasn't in CVS).
>> Since it hasn't been generated (by building the SWIG bindings) it blow
>> up on make dist.  Same is going to be true for the .cxx files.
>> A few choices, which have been discussed previously:
>> * make needs to build the SWIG bindings, then make dist would work
>> * these files get added to SVN, so make dist works whether or not you
>> build the swig bindings.  It also means you could compile the SWIG
>> binding without having SWIG.
>> * these files don't get added to SVN and don't get distributed,
>> thereby forcing anyone who downloads GEOS to have SWIG in order to
>> build the SWIG bindings.
>> I'd prefer the 2nd choice.  What do other think?
>> Charlie
>> Mateusz Loskot wrote:
>>> Paul Ramsey wrote:
>>>> The deed is done.
>>>> http://svn.refractions.net/postgis
>>>> http://svn.refractions.net/geos
>>> I'd like to confirm:
>>> - clean checkout - works
>>> - autogen.sh/configure - works
>>> - make - works
>>> - make check - works
>>> - make dist - does not work
>>> Here is the error message I get when running 'make dist':
>>> make[2]: Entering directory
>>> `/home/mloskot/dev/geos/_svn/geos/swig/python'
>>> make[2]: *** No rule to make target `geos.py', needed by `distdir'.
>>> Stop.
>>> make[2]: Leaving directory
>>> make[1]: *** [distdir] Error 1
>>> make[1]: Leaving directory `/home/mloskot/dev/geos/_svn/geos/swig'
>>> make: *** [distdir] Error 1
>>> Best regards
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
