[geos-devel] Re: [postgis-devel] Re: CVS to SVN move
Charlie Savage cfis at savagexi.com
Wed Jul 26 21:07:49 EDT 2006
How would you do that in automake?
Here is where it is coming from:
SUBDIRS = \
	tests
EXTRA_DIST = \
	python.i \
	geos.pth
#MAINTAINERCLEANFILES = geos_wrap.cxx
#MOSTLYCLEANFILES = geos.py
CLEANFILES = geos_wrap.cxx geos.py
if ENABLE_PYTHON
BUILT_SOURCES = geos_wrap.cxx
python_DATA = geos.pth
pkgpython_PYTHON = geos.py
pkgpyexec_LTLIBRARIES = _geos.la
Charlie
Mateusz Loskot wrote:
> Paul Ramsey wrote:
>> The usual issues apply to putting generated files into the repository:
>> if different people with different swigs generate these files they will
>> potentially clobber each other in the repository and even generate
>> conflicts.
>> A checks out
>> B checks out
>> A generates and updates and commits
>> B generates and updates, conflict!
> Yes, this is the same situation as keeping ./configure script in the
> repo and then every run of autogen.sh will introduce problems.
> If geos.py is generated file, then 'make dist' could operate this
> file optionally, depending on SWIG wrappers are build or not.
> Best regards
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060726/de937717/smime.bin
