[geos-devel] 2 proposed c-api additions
strk at refractions.net strk at refractions.net
Thu Jul 27 21:33:07 EDT 2006
[sorry for late answer]
Ok to add normalize() and equalsExact() to the C-API.
No problem with buffer.xml, it's not even run by 'make check'
(see xmltester/Makefile.am for a list of actually run tests)
--strk;
On Wed, Jul 12, 2006 at 10:07:23PM -0600, Charlie Savage wrote:
> Hi everyone,
> Strk pointed me at the XML test suite as a good source of test data.  So
>  using Ruby, I now load the xml test cases and can run them through the
> SWIG bindings which use the c api.
> To do this, however, requires adding 2 methods to the C API.
> The first method is Geometry::normalize which converts a geometry to its
> cannonincal form.  Without this method, the results from performing
> operations (like buffer) will be in some undetermined order and thus the
> test fails since the actual result does not match the expected result.
> Since this seems to be a generally useful method I'd like to add in to
> the C API.
> The second method is one I mentioned the other day, equalsExact.  The
> XMLTestRunner uses this method to verify that the expected and actual
> results match.  Unfortunately, using equals does not work since it
> returns false in some cases where equalsExact returns true (you can set
> a tolerance with equalsExact).  Once again, this seems like a generally
> useful method so I'd also like to add in to the C API.
> On my local box I have added both of these methods to the C API, and the
>  SWIG bindings now generate the same results as the C++ API (i've only
> done some of the tests so far).
> Note that a number of the XML test cases fail using either API.  For
> example, in buffer.xml roughly half the tests fail.  Is this a problem?
> Charlie
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
