[geos-devel] OverlayOp::DIFFERENCE
strk at refractions.net strk at refractions.net
Mon Jun 5 11:09:15 EDT 2006
I'd rename all values by prefixing the lower-case 'op' to them.
We did it for other enums as well to reduce likelihood of
clashes with #defines.
Also, I'd give the enum a name (OpCode) and update function
signatures to enforce typechecking for them.
--strk;
On Sun, Jun 04, 2006 at 10:50:45PM -0500, Howard Butler wrote:
> Mateusz and strk,
> I was working on building some makefiles for windows of xmltester,
> and I ran into an issue that is confusing.  MSVC 2003 doesn't seem to
> like line 563 of XMLTester.cpp, complaining about not finding a
> constructor:
>         cl -I../../source/headers /MD /GR /O2 /D "NDEBUG" /nologo  /D
> "NOMINMAX"
>  /D "WIN32_LEAN_AND_MEAN" /D "NOGDI"  /GX /c XMLTester.cpp /FoXMLTester.obj
> XMLTester.cpp
> XMLTester.cpp(563) : error C2589: 'constant' : illegal token on right
> side of ':
> XMLTester.cpp(563) : error C2143: syntax error : missing ')' before '::'
> XMLTester.cpp(563) : error C2512:
> 'geos::operation::overlay::overlayOp::overlayO
> p' : no appropriate default constructor available
> XMLTester.cpp(563) : error C2059: syntax error : ')'
> NMAKE : fatal error U1077: 'cl' : return code '0x2'
> Stop.
> If I change the OverlayOp::DIFFERENCE enum to be
> OverlayOp::DIFFERENCE2 in both the call and the header file, things
> compile fine. What's curious is that the C API also calls difference
> this way and doesn't fail to compile.  I'm not sure if it is some
> sort of weird namespace issue.  Any ideas?
> Also, http://geos.builds.hobu.net is building clean for all three
> architectures.
> Howard
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
