[geos-devel] QD (Quad-Double) Approach to Robustness
Paul Ramsey pramsey at refractions.net
Mon Jun 12 18:11:01 EDT 2006
In a conversation with Dale Lutz at GeoAlberta, he mentioned they had
experimented with using the QD library (<http://crd.lbl.gov/~dhbailey/
mpdist/>) in some of their topology processing and found that it was
exceptionally good at bypassing problems caused by reduced
precision.  Presumably this is because all the input data is at
double precision, at most, so relative to the processing precision
(quad) it is quite well behaved.  The approach was so good that in a
race between the old algorithms (double precision but with lots of
tests and bobbing and weaving to catch special cases) and the new
(quad precision, with no special cases at all, just naive algorithms)
the qd won hands down.  So the overhead of the math library on all
cases was not higher than the overhead of finding and handling the
special cases.
Something to look at!
P
