[geos-devel] Swig Update and questions
strk at refractions.net strk at refractions.net
Sat Jun 24 20:43:03 EDT 2006
On Sat, Jun 24, 2006 at 06:30:59PM -0600, Charlie Savage wrote:
> >It's not silly if it makes the SWIG bindings easier to maintain.
> Agreed.  Except the gdal bindings are harder to maintain in some ways
> due to the duplication of code.
> Anyway, the difference in this case is that the GDAL object model is not
> as rich as in GEOS.  GDAL just exposes "geometry" as opposed to point,
> line, etc.
This is what GEOS wants to do as well.
> I think this boils down to three major decisions about the SWIG bindings
> that need to be agreed on:
> 1. What geometry model do clients work with? Just geometry or geometry,
> point, line, etc.
Clients should only work with the C api, unless willing
to follow API revolutions for a couple of years.
> 2.  What compatibility benefits does the C api provide beyond the
> benefits of the generated swig bindings?
The C interface will be careful maintained binary compatible
between versions.
> 3.  How much of GEOS's api gets exposed to clients?
The smallest possible. Ideally none :)
The GEOS API *is* the C-API, previous releases were insane
in exposing that wide C++ interface.
--strk;
