[geos-devel] Swig Update and questions
    Charlie Savage
    cfis at savagexi.com
    Sun Jun 25 22:40:33 EDT 2006
Okay,
 > I'd highly appreciate a combined effort on the binding.
 > I think the best would be SWIG/CAPI, bearing with SWIG version
 > found on debian stable.
I've got the SWIG bindings working with the C API.  I did it by
"faking" classes like in GDAL.  I also implemented a simple geometry
hierarchy of point, line, etc. based on the geometry type id.  Its seems
to work well.
As far as the SWIG version, my guess (and based on a quick google
search) is that Debian stable is using an ancient version.  We really
want to stick with the latest SWIG (1.3.29) version because of two big
reasons:
*  it means the majority of the SWIG interface files can be used for
Python and Ruby.  It also means if someone like Ari wanted to add in a
Perl binding it wouldn't be too hard.
* older versions of Ruby SWIG could not handle giving up ownership of
objects (like when passing a coordinate sequence to a geometry
constructor) which is a must have for GEOS.
Note that GDAL is also using SWIG 1.3.29.
Sean / Hobu - If you send me the API exposed by your custom bindings I
can align the SWIG bindings with them as much as possible.
Strk - Guidance would be appreciated on my emails about threading and
error messages and the various fixes/proposed changes to the C API.
What needs to be done:
*  A couple more hours of implementation
*  A few days of tests - I see the new test suite for the C++ api, I
just plan on porting it to Ruby (great work Mateusz)
* Probably a day more of messing around with the build scripts
I plan on doing this stuff during the course of this week.
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060625/d73cd109/smime.bin
