[geos-devel] Assertions in CoordinateArraySequence
Charlie Savage cfis at savagexi.com
Mon Jun 26 14:40:37 EDT 2006
> I think programmers should not be scared by segmentation faults.
Sure.
But this is a different use case then a C/C++ client.
It is programmers working with GEOS from Ruby/Python. In both languages
array/vetor/list indices are checked and exceptions are raised if they
are out of bounds.  If we want geos to fit in well in these
environments, then it would make sense for GEOS to behave the same way.
Also, I don't think there is anything in either language that you can do
(not including bugs of course or a call to abort) that would cause your
session to abort.
Anyway - don't know why this did not dawnd on me before - but let's do
this.  I'll add in the checks in the wrapper since CoordinateSequence
provides a size method.  That way the api can stay the same but we can
get bounds checkings for Ruby/Python.
Charlie
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060626/354f7cee/smime.bin
