[geos-devel] initGEOS/finishGEOS and multiple subsystems
Mateusz Loskot mateusz at loskot.net
Fri Jun 30 17:17:20 EDT 2006
strk at refractions.net wrote:
>>> With GEOS-3.0.0 initGEOS/finishGEOS do not instantiate/delete a
>>> GeometryFactory anymore. Rather the default GeometryFactory is
>>> used. This should fix the problem.
>> What about backport to 2.2.x with ref-counted proposal? Such
>> changes could would not affect existing code.
> Ok with me.
>> I'd like to repeat that in general, global factory should be
>> replaced with shared object (e.g. managed by shared_ptr from Boost
>> or our own home-made shared smart pointer). static factory can
>> cause problems too:
>> http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.12
> We're using "construct on first use" idiom if I'm not wrong (see faq
> 10.13).
Yes, we are.
But we still need to be careful:
http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.14
Cheers
Mateusz Loskot
http://mateusz.loskot.net
