[geos-devel] initGEOS/finishGEOS and multiple subsystems
Mateusz Loskot mateusz at loskot.net
Fri Jun 30 17:28:39 EDT 2006
strk at refractions.net wrote:
>>>>> With GEOS-3.0.0 initGEOS/finishGEOS do not instantiate/delete a
>>>>> GeometryFactory anymore. Rather the default GeometryFactory is
>>>>> used. This should fix the problem.
>>>> What about backport to 2.2.x with ref-counted proposal? Such
>>>> changes could would not affect existing code.
>>> Ok with me.
>>>> I'd like to repeat that in general, global factory should be
>>>> replaced with shared object (e.g. managed by shared_ptr from Boost
>>>> or our own home-made shared smart pointer). static factory can
>>>> cause problems too:
>>>> http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.12
>>> We're using "construct on first use" idiom if I'm not wrong (see faq
>>> 10.13).
>> Yes, we are.
>> But we still need to be careful:
>> http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.14
> I was waiting for this answer :)
> I don't think anyone's destructor is relying on GeometryFactory use.
Heh, you know, just in case... Evil is Watching ;-)
Cheers
Mateusz Loskot
http://mateusz.loskot.net
