[geos-devel] [UTF] envelope_class_test.cpp fixed for Boost 1.33
Mateusz Łoskot mateusz at loskot.net
Mon Mar 13 09:16:44 EST 2006
strk at refractions.net wrote:
> On Mon, Mar 13, 2006 at 01:44:43PM +0100, Mateusz Å?oskot wrote:
>>So, should I start?
> You're welcome.
OK, so I move to TUT.
I'd suggest to define base dirs structure as follows:
geos\sources
geos\tests\unit
geos\tests\unit\tut  - here sources of TUT
geos\tests\unit\test - here structure of files and subdirs with tests
Is this OK?
Simply, I'd need to have path to include TUT header fixed ;-)
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
