[geos-devel] [UTF] envelope_class_test.cpp fixed for Boost 1.33
Mateusz Łoskot mateusz at loskot.net
Mon Mar 13 09:51:20 EST 2006
strk at refractions.net wrote:
>>>On Mon, Mar 13, 2006 at 01:44:43PM +0100, Mateusz Ã…?oskot wrote:
>>>>So, should I start?
>>>You're welcome.
>>OK, so I move to TUT.
>>I'd suggest to define base dirs structure as follows:
>>geos\sources
>>geos\tests\unit
>>geos\tests\unit\tut  - here sources of TUT
>>geos\tests\unit\test - here structure of files and subdirs with tests
>>Is this OK?
>>Simply, I'd need to have path to include TUT header fixed ;-)
> Isn't it a single header file ?
> I'd place it in
> geos/tests/unit/whatever_it_is_named.h
In fact, TUT consists of 3 files:
tut.h
tut_reporter.h
tut_restartable.h
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
