[geos-devel] Problems with installation of geos on RedHat 9 (third try, i hope this is text)
strk at refractions.net strk at refractions.net
Wed May 17 11:13:16 EDT 2006
Something is wrong with postgis configuration.
1.1.2 should not try to build lwgeom_geos_wrapper.o
when building against geos-3.0.0.
See what's in postgis_geos_version.h
On Wed, May 17, 2006 at 03:21:30PM +0200, Johan V wrote:
> I'm running a Postgresql "8.0.6-1PGDG" database on Redhat 9 and I'm
> trying to install geos (from cvs 3.0.0) for use with Postgis &
> Postgresql. After the configure (see below) I do a make and this is
> the output (see after the configure part):
> lwgeom_geos_wrapper.o lwgeom_geos_wrapper.cpp
> lwgeom_geos_wrapper.cpp:11:23: fout: geos/geom.h: Onbekend bestand of map
--strk;
