[geos-devel] Re: Problems with installation of geos on RedHat 9 (third try, i hope this is text)
alex bodnaru alexbodn at 012.net.il
Mon May 22 04:33:38 EDT 2006
hi all,
the problem with older geos-2.1.4 rpm sources seems to have already been
treated in the following excerpt off google search for the error text:
Bug#356098: FTBFS with G++ 4.1: extra qualification
Sound -c -O -ansi Text.cxx > Sprite.hxx:29: error: extra qualification
'Sprite::' on ... Sound/Sound.hxx:34: error: extra qualification
'Sound::' on member ...
http://lists.debian.org/debian-qa-packages/2006/03/msg00154.html - 7k -
Cached - Similar pages
Extra qualification error - Frugalware Wiki
With the new gcc version most of C++ programs throw an error named extra
qualification. Let's see how we can solve the error. What is the
problem. ...
http://wiki.frugalware.org/Extra_qualification_error - 8k - Cached -
Similar pages
hope this could help you out.
alex
Johan V wrote:
> Hi alex, strk,
> I did run make uninstall in all the version of geos I had. The rpm
> package was already removed before, so now geos on my machine anymore.
> I even removed (make uninstall and rpm -e) postgresql and reinstall
> it. If than I build geos from source, I still get the same problems.
> This is the output from autoheader -v (verbose):
> autoheader: autoheader: running /usr/bin/autom4te --language=autoconf
> --verbose to trace from configure.in
> autoheader: running: /usr/bin/autom4te --language=autoconf  --verbose
> --trace AC_CONFIG_HEADERS:'$$config_h ||= '"'"'$1'"'"';' --trace
> AH_OUTPUT:'$$verbatim{'"'"'$1'"'"'} = '"'"'$2'"'"';' --trace
> AC_DEFINE_TRACE_LITERAL:'$$symbol{'"'"'$1'"'"'} = 1;'
> configure.in >/tmp/ahWZRDj2/traces.pl
> autom4te: autom4te: the trace request object is:
> $VAR1 = bless( [
>                 '0',
>                 0,
>                   '/usr/share/autoconf'
>                   '/usr/share/autoconf/autoconf/autoconf.m4f',
>                   'acsite.m4',
>                   'configure.in'
>                   'm4_pattern_forbid' => 1,
>                   'AC_TYPE_OFF_T' => 1,
>                   'AC_C_VOLATILE' => 1,
>                   'AC_FUNC_CLOSEDIR_VOID' => 1,
>                   'AC_REPLACE_FNMATCH' => 1,
>                   'AC_PROG_LIBTOOL' => 1,
>                   'AC_FUNC_STAT' => 1,
>                   'AC_HEADER_DIRENT' => 1,
>                   'AC_CHECK_FUNCS' => 1
>               ], 'Request' );
> autom4te: running: /usr/bin/m4 --nesting-limit=1024
> --include=/usr/share/autoconf --define=m4_warnings=syntax --debug=aflq
> --fatal-warning --error-output=autom4te.cache/traces.0t
> --trace=AC_CANONICAL_HOST --trace=AC_CANONICAL_SYSTEM
> --trace=AC_CHECK_FUNCS --trace=AC_CHECK_HEADERS --trace=AC_CHECK_LIB
> --trace=AC_CHECK_MEMBERS --trace=AC_CHECK_TYPES
> --trace=AC_CONFIG_AUX_DIR --trace=AC_CONFIG_FILES
> --trace=AC_CONFIG_HEADERS --trace=AC_CONFIG_SUBDIRS --trace=AC_C_CONST
> --trace=AC_C_INLINE --trace=AC_C_VOLATILE --trace=AC_DECL_SYS_SIGLIST
> --trace=AC_DEFINE_TRACE_LITERAL --trace=AC_FUNC_ALLOCA
> --trace=AC_FUNC_CHOWN --trace=AC_FUNC_CLOSEDIR_VOID
> --trace=AC_FUNC_ERROR_AT_LINE --trace=AC_FUNC_FORK
> --trace=AC_FUNC_FSEEKO --trace=AC_FUNC_GETGROUPS
> --trace=AC_FUNC_GETLOADAVG --trace=AC_FUNC_GETMNTENT
> --trace=AC_FUNC_GETPGRP --trace=AC_FUNC_LSTAT
> --trace=AC_FUNC_LSTAT_FOLLOWS_SLASHED_SYMLINK --trace=AC_FUNC_MALLOC
> --trace=AC_FUNC_MBRTOWC --trace=AC_FUNC_MEMCMP --trace=AC_FUNC_MKTIME
> --trace=AC_FUNC_MMAP --trace=AC_FUNC_OBSTACK --trace=AC_FUNC_REALLOC
> --trace=AC_FUNC_SELECT_ARGTYPES --trace=AC_FUNC_SETPGRP
> --trace=AC_FUNC_SETVBUF_REVERSED --trace=AC_FUNC_STAT
> --trace=AC_FUNC_STRCOLL --trace=AC_FUNC_STRERROR_R
> --trace=AC_FUNC_STRFTIME --trace=AC_FUNC_STRNLEN
> --trace=AC_FUNC_STRTOD --trace=AC_FUNC_UTIME_NULL
> --trace=AC_FUNC_VPRINTF --trace=AC_FUNC_WAIT3 --trace=AC_HEADER_DIRENT
> --trace=AC_HEADER_MAJOR --trace=AC_HEADER_STAT --trace=AC_HEADER_STDC
> --trace=AC_HEADER_SYS_WAIT --trace=AC_HEADER_TIME --trace=AC_INIT
> --trace=AC_LIBSOURCE --trace=AC_PATH_X --trace=AC_PROG_AWK
> --trace=AC_PROG_CC --trace=AC_PROG_CPP --trace=AC_PROG_CXX
> --trace=AC_PROG_GCC_TRADITIONAL --trace=AC_PROG_INSTALL
> --trace=AC_PROG_LEX --trace=AC_PROG_LIBTOOL --trace=AC_PROG_LN_S
> --trace=AC_PROG_MAKE_SET --trace=AC_PROG_RANLIB --trace=AC_PROG_YACC
> --trace=AC_REPLACE_FNMATCH --trace=AC_STRUCT_ST_BLOCKS
> --trace=AC_STRUCT_TIMEZONE --trace=AC_STRUCT_TM --trace=AC_SUBST
> --trace=AC_TYPE_MODE_T --trace=AC_TYPE_OFF_T --trace=AC_TYPE_PID_T
> --trace=AC_TYPE_SIGNAL --trace=AC_TYPE_SIZE_T --trace=AC_TYPE_UID_T
> --trace=AH_OUTPUT --trace=AM_AUTOMAKE_VERSION --trace=AM_CONDITIONAL
> --trace=AM_GNU_GETTEXT --trace=AM_INIT_AUTOMAKE
> --trace=AM_MAINTAINER_MODE --trace=AM_PROG_CC_C_O --trace=include
> --trace=m4_include --trace=m4_pattern_allow --trace=m4_pattern_forbid
> --reload-state=/usr/share/autoconf/autoconf/autoconf.m4f acsite.m4
> configure.in </dev/null >autom4te.cache/output.0t
> ' is already registered with AC_CONFIG_FILES.
> autoconf/status.m4:844: AC_CONFIG_FILES is expanded from...
> configure.in:271: the top level
> autom4te: /usr/bin/m4 failed with exit status: 1
> autoheader: /usr/bin/autom4te failed with exit status: 1
> Which additional packages do you mean, because I have the
> autoconf/autoheader package (version 2.57), libtoolize 1.4.3, automake
> 1.6.3 and m4 1.4.1-13. And from the error I get I can by doing
> autoheader I don't know with package is missing:
> The error point to configure.in:271, were I found this: ]) (and rule
> 270: tools/geos-config)
> Therefore stand in the ouput of autoheader autoconf/status.m4:844, if
> I look at this file on line 843 and 844 than i see this:
>    ac_config_files="$ac_config_files m4_normalize([$1])"
> If i try to install it as described on that website "nccoos", than I
> get the same errrors as before during the 'make' fase of the rebuild
> proccess:
> mkdir .libs
> i686-pc-linux-gnu-g++ -DHAVE_CONFIG_H -I. -I. -I../../source/headers
> -I../../source/headers/geos -I../../source/headers
> -DGEOS_VERSION=2.1.4 -O2 -g -pipe -march=i386 -mcpu=i686 -MT
> Coordinate.lo -MD -MP -MF .deps/Coordinate.Tpo -c Coordinate.cpp
> -DPIC
> `-mcpu=' is deprecated. Use `-mtune=' or '-march=' instead.
> ../../source/headers/geos/geom.h:358: error: extra qualification
> 'geos::Coordinate::' on member 'setNull'
> ../../source/headers/geos/geom.h:364: error: extra qualification
> 'geos::Coordinate::' on member 'getNull'
> ../../source/headers/geos/geom.h:368: error: extra qualification
> 'geos::Coordinate::' on member 'Coordinate'
> ../../source/headers/geos/geom.h:374: error: extra qualification
> ../../source/headers/geos/geom.h:380: error: extra qualification
> ../../source/headers/geos/geom.h:386: error: extra qualification
> ../../source/headers/geos/geom.h:451: error: extra qualification
> 'geos::Coordinate::' on member 'hashCode'
> make[2]: *** [Coordinate.lo] Error 1
> make[2]: Leaving directory `/usr/src/redhat/BUILD/geos-2.1.4/source/geom'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/usr/src/redhat/BUILD/geos-2.1.4/source'
> make: *** [all-recursive] Error 1
> error: Bad exit status from /var/tmp/rpm-tmp.1631 (%build)
> RPM build errors:
>    Bad exit status from /var/tmp/rpm-tmp.92644 (%build)
> 2006/5/20, alex bodnaru <alexbodn at 012.net.il>:
>> hi johan,
>> though not an expert in redhat, i'll try to direct you in a valid
>> direction.
>> first, as i see you have already tryed to install geos before, i'd
>> suggest you to uninstall it:
>> geos related rpm you have installed, uninstall using rpm (check how to
>> in rpm manuals).
>> go to the geos source directory of each version you ever tryed to
>> install from sources on your current system and run: make uninstall.
>> then, i'd suggest you to use the procedure described at
>> http://nccoos.org/Members/cbc/how-i-installed-postgis, at least for the
>> geos part there.
>> you may also build geos from sources on your system, but then you may
>> need additional tools and packages. see eventual error message for
>> completing the missing files. i'd suggest you search for and install the
>> rpms that contain this files, and not just the source packages
>> themselves.
>> i know this message is very schematic, but please use your understanding
>> and creativity to fill the evident gaps in my knowledge.
>> good luck,
>> alex
>> Johan V wrote:
>> > I hope you know the solution to this problems, I'm not a linux expert
>> > like you maybe already noticed, but if you can tell me what I'm doing
>> > wrong that would be great
>> > Thx,
>> > Johan
>> > 2006/5/18, Johan V <jvhoppli at gmail.com>:
>> >> If i run ./autogen.sh (after doing a chmod +775 autogen.sh) i get
>> >> : bad interpreter: No such file or directory
>> >> If i look at this shell script and i try to execute the command one by
>> >> one, than i get:
>> >> [root at 192 geos]# uname -s
>> >> Linux
>> >> [root at 192 geos]# autoheader
>> >> [root at 192 geos]# aclocal -I macros
>> >> [root at 192 geos]# libtoolize --force --copy
>> >> [root at 192 geos]# automake --add-missing --copy
>> >> configure.in:31: `automake requires `AM_CONFIG_HEADER', not
>> >> `AC_CONFIG_HEADER'
>> >> configure.in: installing `./mkinstalldirs'
>> >> configure.in: installing `./missing'
>> >> aclocal.m4:4665: installing `./py-compile'
>> >> capi/Makefile.am: installing `./depcomp'
>> >> configure.in:32: required file `source/headers/config.h.in' not found
>> >> 2006/5/18, strk at refractions.net <strk at refractions.net>:
>> >> > On Thu, May 18, 2006 at 02:31:42PM +0200, Johan V wrote:
>> >> > > I downloaded the latest snapshot from the website (the tar.bz
>> file),
>> >> > > so not with the cvs commando. So now, I tried to do it with cvs
>> (via
>> >> > > another person's internet connection, because i'm behind a proxy
>> >> > > server, and don't now how to configure cvs correctly), but in de
>> >> > > directory geos there is no configure file nor a Makefile, only an
>> >> > > configure.in and a Makefile.am, and neither are those files in the
>> >> > > source subdirectory (only config.log and Makefile.am and
>> >> Makefile.vc).
>> >> > > Is it possible to put the latest snapshot as a tar.bz file on the
>> >> > > website please.
>> >> > Run ./autogen.sh in your working directory.
>> >> > --strk;
>> >> > _______________________________________________
>> >> > geos-devel mailing list
>> >> > geos-devel at geos.refractions.net
>> >> > http://geos.refractions.net/mailman/listinfo/geos-devel
