[geos-devel] GEOS-3.0.0rc2
strk at refractions.net strk at refractions.net
Sun Nov 5 10:30:07 EST 2006
Charlie, thank you, could you also updated the ChangeLog file ?
(we're manually mantaining it)
--strk;
On Sat, Nov 04, 2006 at 05:26:53PM -0700, Charlie Savage wrote:
> Thanks - changed checked in.  I will have to do some testing, but
> everything compiles now on Linux.
> Charlie
> Paul Ramsey wrote:
> >Fixed
> >On 4-Nov-06, at 1:13 PM, Charlie Savage wrote:
> >>Okay - I've got a fix.  But I can't check in, SVN seems to have gone
> >>down?
> >>Charlie
> >>strk at refractions.net wrote:
> >>>Charlie, do you think you can fix this shortly ?
> >>>(otherwise I'd ship rc2 with *known* broken swig bindings)
> >>>--strk;
> >>>On Sat, Nov 04, 2006 at 10:41:29AM +0100, Markus Schaber wrote:
> >>>>Hi, Charlie,
> >>>>>Hmm, looks like something changed in a header file.  I'll take a
> >>>>>look at
> >>>>>see what's up.
> >>>>That seems to be the problem that was discussed here the last days.
> >>>>Due to the typedef, the header declarations were wrong. Accidentally,
> >>>>there was declared a constant pointer to a Geometry, not a pointer to a
> >>>>constant Geometry, in the C-API. See the archives for details.
> >>>>Fixing this might break source compatibility for clients, but should
> >>>>not break binary compatibility.
> >>>>The same problem was triggered in capi/geostest.c and PostGIS.
> >>>>HTH,
> >>>>Markus
> >>>_______________________________________________
> >>>geos-devel mailing list
> >>>geos-devel at geos.refractions.net
> >>>http://geos.refractions.net/mailman/listinfo/geos-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
