[geos-devel] GEOS-3.0.0rc2
strk at refractions.net strk at refractions.net
Mon Nov 6 11:08:59 EST 2006
On Mon, Nov 06, 2006 at 08:04:02AM -0800, Paul Ramsey wrote:
> I ran "make dist" to get the tarball, extracted that and made sure it
> built, then ran "make distcheck" and saw all the tests run.  I was
> not looking closely at the output, only at general conformance.  So
> "make dist" will need to be fixed to include that file.
Did you run ./autogen.sh and ./configure again ?
I'm pretty sure I've fixed this (should be fixed in both trunk
and tags/3.0.0rc2 )
--strk;
