[geos-devel] Building GEOS 3.0.0 on windows
strk at refractions.net strk at refractions.net
Fri Nov 10 10:58:07 EST 2006
On Fri, Nov 10, 2006 at 09:40:45AM -0600, Howard Butler wrote:
> At 09:22 AM 11/10/2006, strk at refractions.net wrote:
> >On Fri, Nov 10, 2006 at 09:07:33AM -0600, Howard Butler wrote:
> >> >#define GEOS_VERSION "3.0.0rc1"
> >> is version block of geos_c.h after running configure
> >Did you run autogen.sh ?
> >Version is in configure.ac, then goes to configure, and finally
> >goes into the geos_c.h file.
> I shouldn't have to because configure, et.al should be rerun and
> recommitted after each release, right?
Not committed (./configure should NOT be in SVN), but
./autogen.sh should be run before 'make dist', which should
give you the new version.
Paul ? Any idea ?
--strk;
