[geos-devel] Building GEOS 3.0.0 on windows
Paul Ramsey pramsey at refractions.net
Fri Nov 10 12:52:54 EST 2006
I just committed that change, it's done.
On 10-Nov-06, at 9:51 AM, strk at refractions.net wrote:
> On Fri, Nov 10, 2006 at 09:46:36AM -0800, Paul Ramsey wrote:
>> When I run autogen.sh I get the right versions into configure.  When
>> I run configure I get the right versions into the .h and (now) .h.vc
>> files.
> .h.vc files are not automatically generated, if you get correct
> versions
> there that's due to hobu commits. Since we need to run ./autogen.sh
> and
> ./configure to use the 'make dist' rule I guess having the .h.vc files
> created by ./configure (or a dist-hook) is a viable solution.
> Win32 volunteers ? (no, don't need to make a batch command, just a
> shell
> script)
> --strk;
