[geos-devel] Building GEOS with GDAL
Howard Butler hobu at iastate.edu
Tue Nov 14 09:41:53 EST 2006
http://lists.refractions.net/pipermail/geos-devel/2006-November/002670.html
At 07:00 AM 11/14/2006, strk at refractions.net wrote:
>On Tue, Nov 14, 2006 at 12:50:33PM +0000, Mir Hassan Ali wrote:
> > Hi
> > I am also getting these warnings for geos_c.h file. Are these of any
> > significance?
>mmm... maybe the type specifier is just placed in the wrong
>way:
>133: extern GEOSGeometry* GEOS_DLL GEOSGeomFromWKT(const char *wkt);
>134: extern char GEOS_DLL *GEOSGeomToWKT(const GEOSGeometry* g);
>Since you don't get a warning on 134 I suppose it should be:
>134: extern char * GEOS_DLL GEOSGeomToWKT(const GEOSGeometry* g);
>Can you try ?
>--strk;
> > ..\ogr\geos_c.h(134) : warning C4518: '__declspec(dllexport ) ' :
> > storage-class or type specifier(s) unexpected here; ignored
> > ..\ogr\geos_c.h(151) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(154) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(168) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(174) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(225) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(226) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(227) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(234) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(236) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(239) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(256) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(257) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(258) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(260) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(261) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(262) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(264) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(265) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(266) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(267) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(274) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(277) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(278) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(279) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(344) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(357) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(364) : warning C4518: '__declspec(dllexport ) ' :
> > ..\ogr\geos_c.h(373) : warning C4518: '__declspec(dllexport ) ' :
> > I am still unable to build GDAL with GEOS.
> > Best Regards
> > Mir
> > On 11/14/06, strk at refractions.net <strk at refractions.net> wrote:
> > >Argh.. sounds related to latest 'const-correctness' or 'integer
> > >signedness'
> > >changes in the CAPI header file, is this possible ?
> > >I'm not an expert of the __declspec(dllexport) thing ...
> > >--strk;
> > >On Mon, Nov 13, 2006 at 05:13:30PM +0000, Mir Hassan Ali wrote:
> > >> Hi Frank,
> > >> I downloaded the GDAL snapshot on 6th November 2006, so i assume it
> > >includes
> > >> the latest changes. When I compile it without the GEOS support, i.e the
> > >> following lines are commented in the nmake.opt file are commented:
> > >> GEOS_CFLAGS = -IC:/GEOS/trunk/capi -DHAVE_GEOS
> > >> GEOS_LIB = C:/GEOS/trunk/source/geos_c_i.lib
> > >> But when I uncomment these lines and try to build the API it gives me
> > >the
> > >> following link errors:
> > >> Creating library gdal_i.lib and object gdal_i.exp
> > >> ogr.lib(ogrgeometry.obj) : error LNK2019: unresolved external symbol
> > >> _GEOSGeomFr
> > >> omWKB_buf referenced in function "public: virtual struct GEOSGeom_t *
> > >> __thiscall
> > >> OGRGeometry::exportToGEOS(void)const " (
> > >> ?exportToGEOS at OGRGeometry@@UBEPAUGEOSGe
> > >> om_t@@XZ)
> > >> _GEOSConvex
> > >> Hull referenced in function "public: virtual class OGRGeometry *
> > >__thiscall
> > >> OGRG
> > >> eometry::ConvexHull(void)const " (?ConvexHull at OGRGeometry@@UBEPAV1 at XZ )
> > >> ogr.lib(ogrgeometry.obj ) : error LNK2019: unresolved external symbol
> > >> _GEOSBounda
> > >> ry referenced in function "public: virtual class OGRGeometry *
> > >__thiscall
> > >> OGRGeo
> > >> metry::getBoundary(void)const " ( ?getBoundary at OGRGeometry@@UBEPAV1 at XZ)
> > >> _GEOSBuffer
> > >> referenced in function "public: virtual class OGRGeometry * __thiscall
> > >> OGRGeome
> > >> try::Buffer(double,int)const " ( ?Buffer at OGRGeometry@@UBEPAV1 at NH@Z)
> > >> _GEOSInters
> > >> ection referenced in function "public: virtual class OGRGeometry *
> > >> __thiscall OG
> > >> RGeometry::Intersection(class OGRGeometry const *)const "
> > >> (?Intersection at OGRGeom
> > >> etry@@UBEPAV1 at PBV1@@Z)
> > >> _GEOSUnion
> > >> OGRGeomet
> > >> ry::Union(class OGRGeometry const *)const "
> > >> (?Union at OGRGeometry@@UBEPAV1 at PBV1@@Z
> > >> _GEOSDiffer
> > >> ence referenced in function "public: virtual class OGRGeometry *
> > >__thiscall
> > >> OGRG
> > >> eometry::Difference(class OGRGeometry const *)const " (
> > >> ?Difference at OGRGeometry@@
> > >> UBEPAV1 at PBV1@@Z)
> > >> _GEOSSymDif
> > >> ference referenced in function "public: virtual class OGRGeometry *
> > >> __thiscall O
> > >> GRGeometry::SymmetricDifference(class OGRGeometry const *)const "
> > >> (?SymmetricDif
> > >> ference at OGRGeometry@@UBEPAV1 at PBV1@@Z)
> > >> ogr.lib(ogrpolygon.obj) : error LNK2019: unresolved external symbol
> > >> _GEOSGetCent
> > >> roid referenced in function "public: virtual int __thiscall
> > >> OGRPolygon::Centroid
> > >> (class OGRPoint *)const " ( ?Centroid at OGRPolygon@@UBEHPAVOGRPoint@@@Z)
> > >> gdal13.dll : fatal error LNK1120: 9 unresolved externals
> > >> NMAKE : fatal error U1077: 'link' : return code '0x460'
> > >> Stop.
> > >> Is there something else that I need to do in addition to the changes
> > >> mentioned above to the nmake.opt file. Please note that I am using the
> > >> latest version of the GEOS API. I checked it out from the subversion
> > >trunk
> > >> and built it. It builds fine without any errors or warnings.
> > >> Best Regards
> > >_______________________________________________
> > >geos-devel mailing list
> > >geos-devel at geos.refractions.net
> > >http://geos.refractions.net/mailman/listinfo/geos-devel
>  /"\    ASCII Ribbon Campaign
>  \ /    Respect for low technology.
>   X     Keep e-mail messages readable by any computer system.
>  / \    Keep it ASCII.
