[geos-devel] strange test case
Carl Anderson carl.anderson at co.fulton.ga.us
Tue Nov 14 14:46:18 EST 2006
strk,
I have finally isolated an example that generates the assertion error.
I get the error:
bufferOriginalPrecision failed, trying with reduced precision
Scaler: offsetX,Y: 0,0 scaleFactor: 25
XMLTester: ../source/headers/geos/noding/SegmentString.h:167: void
geos::noding::SegmentString::testInvariant() const: Assertion
`pts->size() == npts' failed.
Abort
The error occurs on Intel PIII and P4 chips, but have not been able to
produce the error in AMD Athlon chips.
I used gcc 4.1.1 with the GEOS default -O2 flags.
It may or may not produce an error for you.
run the attached into XMLTester.
BTW this example is not a valid geometry.  I was created through a
series of PostGIS operations,
Difference() and Simplify().
C.
Carl Anderson
GIS Manager Fulton County, Georgia
404.730.8026
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20061114/78a2793f/geos_exception.xml
