[geos-devel] troubles understanding GEOS
Del Cacho, Carlos (Carlos) delcacho at lucent.com
Tue Nov 28 09:08:43 EST 2006
PostGIS may be sufficient for what you want to do.
Just remember you cannot create spatial columns through CREATE statements,
use AddGeometryColumn instead:
http://postgis.refractions.net/docs/ch04.html#id2523380
And... you need to create a spatial index on the geometry column for
enhancing query speed:
http://postgis.refractions.net/docs/ch04.html#id2524285
Cheers,
Carlos del Cacho
-----Original Message-----
[mailto:geos-devel-bounces at geos.refractions.net]On Behalf Of Tobias
Nothdurft
Sent: martes, 28 de noviembre de 2006 14:59
To: GEOS Development List
Subject: Re: [geos-devel] troubles understanding GEOS
Hi.
> If you want to use the quadtree-functionality of GEOS for some goemetry
> processing, you don't need PostgreSQL and PostGIS at all.
> GEOS is just a geometry processing library, geos by itsself doesn't do
> anything with databases.
> You can use PostGIS/PostgreSQL for storage of your geometries, or
> GDAL/OGR, but you don't have to.
I see!
But there has to be a gain to link my programm with some kind of database
when i
have to handle hundreds or thousands of objects! :) So how do I accomplish
this
connection? With the WKT-reader and -writer?
Tobias
geos-devel mailing list
geos-devel at geos.refractions.net
http://geos.refractions.net/mailman/listinfo/geos-devel
