[geos-devel] dirlist.mk not found
Mateusz Loskot mateusz at loskot.net
Thu Sep 28 09:39:58 EDT 2006
francesco wrote:
> I am trying to compile in windows the latest version of geos using
> Visual Studio 6.1, but it keeps saying that the file "dirlist.mk" is
> not found.  Where do I find such file?
Show us the command you run.
You should step into the <GEOSROOT>/source directory
The dirlist.mk file is in the <GEOSROOT>/source
http://svn.refractions.net/geos/trunk/source/dirlist.mk
In fact, this file is likely not up to date but it should not prevent
you from building GEOS. dirlist.mk is *only* used by 'clean' target when
you run command:
nmake -f Makefile.vc clean
Cheers
Mateusz Loskot
http://mateusz.loskot.net
