[geos-devel] Memory problems while parsing WKB
Mateusz Loskot mateusz at loskot.net
Wed Apr 18 14:52:51 EDT 2007
Andreas Volz wrote:
> Hello,
> I've problems to parse WKB with GEOS. Here is my sample application:
> It works in most cases, but sometimes the result values are broken or I
> get a segfault. So I used valgrind to get some more information. I got
> this as result:
> ==17755== Invalid read of size 4
> ==17755==    at 0x41327FE: geos::PrecisionModel::makePrecise(double)
> const (in /usr/lib/libgeos.so.2.2.3) ==17755==    by 0x401D5D5A: ???
> ==17755==  Address 0x460A544 is 4 bytes inside a block of size 16 free'd
> ==17755==    at 0x40212FA: operator delete(void*)
> (in /usr/lib/valgrind/x86-linux/vgpreload_memcheck.so) ==17755==    by
> 0x4132695: geos::PrecisionModel::~PrecisionModel()
> (in /usr/lib/libgeos.so.2.2.3) ==17755==    by 0x42F083B: (below main)
> (in /lib/libc-2.5.so) ==17755==
> ... and this as often as I read coordinates.
> Any ideas why PrecisionModel has this problem? A problem in GEOS WKBParser or my
> application?
Andreas,
Could you provide us with simple but generic program presenting the
problem? Ideally, if the example:
- refers only to GEOS, but not to any database
- shows values of coordinates causing the crash, just hardcoded in the
program
Your code is not usable, because it's specific to your particular
environment and data.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
