[geos-devel] svn checkout problem
Hugh Jennings hugh at photosat.ca
Mon Dec 10 16:20:05 EST 2007
I was hoping to get the current version of your code but I am
experiencing a small problem. The configure script does not appear to be
being checked out when I try to get your code.
I believe am using the command as stated on your website.  I have
attached a file which shows the command and the results.
I would appreciate any suggestions as to what I can do differently.
Thanks,
Hugh
[root at pc033 geos]#  svn checkout http://svn.osgeo.org/geos/trunk geos
Restored 'geos/makefile.vc'
Restored 'geos/AUTHORS'
Restored 'geos/configure.in'
Restored 'geos/acsite.m4'
Restored 'geos/ChangeLog'
Restored 'geos/README'
Restored 'geos/HOWTO_RELEASE'
Restored 'geos/TODO'
Restored 'geos/INSTALL'
Restored 'geos/COPYING'
Restored 'geos/Makefile.am'
Restored 'geos/autogen.sh'
Restored 'geos/NEWS'
A  geos/debian
A  geos/debian/control
A  geos/debian/compat
A  geos/debian/libgeos.dirs
A  geos/debian/libgeos-dev.docs
A  geos/debian/changelog
A  geos/debian/libgeos.install
A  geos/debian/libgeos-dev.manpages
A  geos/debian/rules
A  geos/debian/geos-config.1
A  geos/debian/libgeos-dev.dirs
A  geos/debian/libgeos-doc.doc-base
A  geos/debian/makedoc
A  geos/debian/libgeos-dev.install
A  geos/debian/watch
A  geos/debian/copyright
A  geos/debian/libgeos.docs
A  geos/debian/Makefile
A  geos/debian/libgeos-doc.docs
A  geos/debian/README.Debian
A  geos/macros
A  geos/macros/python.m4
A  geos/macros/ruby.m4
A  geos/macros/ac_python_devel.m4
A  geos/macros/boost.m4
A  geos/macros/Makefile.am
A  geos/macros/ac_pkg_swig.m4
A  geos/macros/geos.m4
U  geos/ChangeLog
A  geos/build
A  geos/build/msvc80
A  geos/build/msvc80/geos_lib
A  geos/build/msvc80/geos_lib/geos_lib.vcproj
A  geos/build/msvc80/geos.sln
A  geos/build/msvc80/geos.vsprops
A  geos/build/msvc80/geos_c_dll
A  geos/build/msvc80/geos_c_dll/geos_c_dll.vcproj
A  geos/build/msvc80/geos_unit
A  geos/build/msvc80/geos_unit/geos_unit.vcproj
A  geos/build/msvc80/README
A  geos/build/msvc80/geos_python
A  geos/build/msvc80/geos_python/geos_python.vcproj
A  geos/build/msvc80/geos_ruby
A  geos/build/msvc80/geos_ruby/geos_ruby.vcproj
A  geos/build/bjam
A  geos/build/bjam/geos_c
A  geos/build/bjam/geos_c/Jamfile
A  geos/build/bjam/Jamroot
A  geos/build/bjam/geos_unit
A  geos/build/bjam/geos_unit/Jamfile
A  geos/build/bjam/geos/Jamfile
A  geos/build/README
A  geos/source
A  geos/source/dirlist.mk
A  geos/source/inlines.cpp
A  geos/source/Makefile.vc
A  geos/source/algorithm
A  geos/source/algorithm/InteriorPointArea.cpp
A  geos/source/algorithm/SIRtreePointInRing.cpp
A  geos/source/algorithm/HCoordinate.cpp
A  geos/source/algorithm/CentroidArea.cpp
A  geos/source/algorithm/SimplePointInAreaLocator.cpp
A  geos/source/algorithm/RobustLineIntersector.cpp
A  geos/source/algorithm/LineIntersector.cpp
A  geos/source/algorithm/RobustDeterminant.cpp
A  geos/source/algorithm/SimplePointInRing.cpp
A  geos/source/algorithm/PointLocator.cpp
A  geos/source/algorithm/InteriorPointLine.cpp
A  geos/source/algorithm/InteriorPointPoint.cpp
A  geos/source/algorithm/CentroidLine.cpp
A  geos/source/algorithm/MCPointInRing.cpp
A  geos/source/algorithm/CentroidPoint.cpp
A  geos/source/algorithm/NonRobustLineIntersector.cpp
A  geos/source/algorithm/CGAlgorithms.cpp
A  geos/source/algorithm/MinimumDiameter.cpp
A  geos/source/algorithm/ConvexHull.cpp
A  geos/source/algorithm/Makefile.am
A  geos/source/algorithm/NotRepresentableException.cpp
A  geos/source/geom
A  geos/source/geom/MultiPolygon.cpp
A  geos/source/geom/MultiPoint.cpp
A  geos/source/geom/Triangle.cpp
A  geos/source/geom/GeometryCollection.cpp
A  geos/source/geom/CoordinateArraySequenceFactory.cpp
A  geos/source/geom/CoordinateSequenceFactory.cpp
A  geos/source/geom/Location.cpp
A  geos/source/geom/LineSegment.cpp
A  geos/source/geom/PrecisionModel.cpp
A  geos/source/geom/Envelope.cpp
A  geos/source/geom/LineString.cpp
A  geos/source/geom/CoordinateArraySequence.cpp
A  geos/source/geom/CoordinateSequence.cpp
A  geos/source/geom/GeometryFactory.cpp
A  geos/source/geom/GeometryComponentFilter.cpp
A  geos/source/geom/Dimension.cpp
A  geos/source/geom/GeometryList.cpp
A  geos/source/geom/Coordinate.cpp
A  geos/source/geom/Polygon.cpp
A  geos/source/geom/Makefile.am
A  geos/source/geom/MultiLineString.cpp
A  geos/source/geom/Point.cpp
A  geos/source/geom/LinearRing.cpp
A  geos/source/geom/IntersectionMatrix.cpp
A  geos/source/geom/Geometry.cpp
A  geos/source/geom/util
A  geos/source/geom/util/GeometryTransformer.cpp
A  geos/source/geom/util/LinearComponentExtracter.cpp
A  geos/source/geom/util/GeometryEditor.cpp
A  geos/source/geom/util/ShortCircuitedGeometryVisitor.cpp
A  geos/source/geom/util/CoordinateOperation.cpp
A  geos/source/geom/util/Makefile.am
A  geos/source/geom/util/PolygonExtracter.cpp
A  geos/source/geom/util/PointExtracter.cpp
A  geos/source/precision
A  geos/source/precision/EnhancedPrecisionOp.cpp
A  geos/source/precision/GeometrySnapper.cpp
A  geos/source/precision/LineStringSnapper.cpp
A  geos/source/precision/Makefile.am
A  geos/source/precision/CommonBitsOp.cpp
A  geos/source/precision/CommonBits.cpp
A  geos/source/precision/CommonBitsRemover.cpp
A  geos/source/precision/SimpleGeometryPrecisionReducer.cpp
A  geos/source/simplify
A  geos/source/simplify/TaggedLineStringSimplifier.cpp
A  geos/source/simplify/DouglasPeuckerSimplifier.cpp
A  geos/source/simplify/LineSegmentIndex.cpp
A  geos/source/simplify/TopologyPreservingSimplifier.cpp
A  geos/source/simplify/TaggedLineSegment.cpp
A  geos/source/simplify/Makefile.am
A  geos/source/simplify/DouglasPeuckerLineSimplifier.cpp
A  geos/source/simplify/TaggedLineString.cpp
A  geos/source/simplify/TaggedLinesSimplifier.cpp
A  geos/source/planargraph
A  geos/source/planargraph/PlanarGraph.cpp
A  geos/source/planargraph/DirectedEdgeStar.cpp
A  geos/source/planargraph/NodeMap.cpp
A  geos/source/planargraph/Edge.cpp
A  geos/source/planargraph/Node.cpp
A  geos/source/planargraph/algorithm
A  geos/source/planargraph/algorithm/ConnectedSubgraphFinder.cpp
A  geos/source/planargraph/DirectedEdge.cpp
A  geos/source/planargraph/Makefile.am
A  geos/source/planargraph/Subgraph.cpp
A  geos/source/operation
A  geos/source/operation/GeometryGraphOperation.cpp
A  geos/source/operation/polygonize
A  geos/source/operation/polygonize/PolygonizeGraph.cpp
A  geos/source/operation/polygonize/Polygonizer.cpp
A  geos/source/operation/polygonize/EdgeRing.cpp
A  geos/source/operation/polygonize/PolygonizeEdge.cpp
A  geos/source/operation/polygonize/Makefile.am
A  geos/source/operation/polygonize/PolygonizeDirectedEdge.cpp
A  geos/source/operation/valid
A  geos/source/operation/valid/TopologyValidationError.cpp
A  geos/source/operation/valid/SimpleNestedRingTester.cpp
A  geos/source/operation/valid/QuadtreeNestedRingTester.cpp
A  geos/source/operation/valid/ConnectedInteriorTester.cpp
A  geos/source/operation/valid/SweeplineNestedRingTester.cpp
A  geos/source/operation/valid/Makefile.am
A  geos/source/operation/valid/ConsistentAreaTester.cpp
A  geos/source/operation/valid/IsValidOp.cpp
A  geos/source/operation/valid/RepeatedPointTester.cpp
A  geos/source/operation/predicate
A  geos/source/operation/predicate/SegmentIntersectionTester.cpp
A  geos/source/operation/predicate/RectangleContains.cpp
A  geos/source/operation/predicate/Makefile.am
A  geos/source/operation/predicate/RectangleIntersects.cpp
A  geos/source/operation/overlay
A  geos/source/operation/overlay/LineBuilder.cpp
A  geos/source/operation/overlay/PolygonBuilder.cpp
A  geos/source/operation/overlay/OverlayNodeFactory.cpp
A  geos/source/operation/overlay/OverlayOp.cpp
A  geos/source/operation/overlay/PointBuilder.cpp
A  geos/source/operation/overlay/FuzzyPointLocator.cpp
A  geos/source/operation/overlay/OverlayResultValidator.cpp
A  geos/source/operation/overlay/OffsetPointGenerator.cpp
A  geos/source/operation/overlay/EdgeSetNoder.cpp
A  geos/source/operation/overlay/Makefile.am
A  geos/source/operation/overlay/ElevationMatrix.cpp
A  geos/source/operation/overlay/ElevationMatrixCell.cpp
A  geos/source/operation/overlay/MinimalEdgeRing.cpp
A  geos/source/operation/overlay/MaximalEdgeRing.cpp
A  geos/source/operation/IsSimpleOp.cpp
A  geos/source/operation/linemerge
A  geos/source/operation/linemerge/LineMergeDirectedEdge.cpp
A  geos/source/operation/linemerge/LineSequencer.cpp
A  geos/source/operation/linemerge/Makefile.am
A  geos/source/operation/linemerge/LineMergeGraph.cpp
A  geos/source/operation/linemerge/LineMerger.cpp
A  geos/source/operation/linemerge/EdgeString.cpp
A  geos/source/operation/linemerge/LineMergeEdge.cpp
A  geos/source/operation/Makefile.am
A  geos/source/operation/buffer
A  geos/source/operation/buffer/OffsetCurveSetBuilder.cpp
A  geos/source/operation/buffer/BufferBuilder.cpp
A  geos/source/operation/buffer/OffsetCurveBuilder.cpp
A  geos/source/operation/buffer/BufferSubgraph.cpp
A  geos/source/operation/buffer/BufferOp.cpp
A  geos/source/operation/buffer/Makefile.am
A  geos/source/operation/buffer/OffsetCurveVertexList.h
A  geos/source/operation/buffer/SubgraphDepthLocater.cpp
A  geos/source/operation/buffer/RightmostEdgeFinder.cpp
A  geos/source/operation/distance
A  geos/source/operation/distance/GeometryLocation.cpp
A  geos/source/operation/distance/Makefile.am
A  geos/source/operation/distance/DistanceOp.cpp
A  geos/source/operation/distance/ConnectedElementLocationFilter.cpp
A  geos/source/operation/distance/ConnectedElementPointFilter.cpp
A  geos/source/operation/relate
A  geos/source/operation/relate/EdgeEndBundleStar.cpp
A  geos/source/operation/relate/EdgeEndBuilder.cpp
A  geos/source/operation/relate/RelateNode.cpp
A  geos/source/operation/relate/RelateNodeGraph.cpp
A  geos/source/operation/relate/EdgeEndBundle.cpp
A  geos/source/operation/relate/Makefile.am
A  geos/source/operation/relate/RelateNodeFactory.cpp
A  geos/source/operation/relate/RelateComputer.cpp
A  geos/source/operation/relate/RelateOp.cpp
A  geos/source/io
A  geos/source/io/ByteOrderValues.cpp
A  geos/source/io/WKBWriter.cpp
A  geos/source/io/StringTokenizer.cpp
A  geos/source/io/Unload.cpp
A  geos/source/io/WKTWriter.cpp
A  geos/source/io/WKBReader.cpp
A  geos/source/io/Makefile.am
A  geos/source/io/WKTReader.cpp
A  geos/source/io/ParseException.cpp
A  geos/source/io/ByteOrderDataInStream.cpp
A  geos/source/io/Writer.cpp
A  geos/source/index
A  geos/source/index/chain
A  geos/source/index/chain/MonotoneChainSelectAction.cpp
A  geos/source/index/chain/MonotoneChain.cpp
A  geos/source/index/chain/Makefile.am
A  geos/source/index/chain/MonotoneChainBuilder.cpp
A  geos/source/index/chain/MonotoneChainOverlapAction.cpp
A  geos/source/index/bintree
A  geos/source/index/bintree/NodeBase.cpp
A  geos/source/index/bintree/Root.cpp
A  geos/source/index/bintree/Interval.cpp
A  geos/source/index/bintree/Node.cpp
A  geos/source/index/bintree/Bintree.cpp
A  geos/source/index/bintree/Key.cpp
A  geos/source/index/bintree/Makefile.am
A  geos/source/index/strtree
A  geos/source/index/strtree/Interval.cpp
A  geos/source/index/strtree/Makefile.am
A  geos/source/index/strtree/STRtree.cpp
A  geos/source/index/strtree/AbstractNode.cpp
A  geos/source/index/strtree/ItemBoundable.cpp
A  geos/source/index/strtree/AbstractSTRtree.cpp
A  geos/source/index/strtree/SIRtree.cpp
A  geos/source/index/Makefile.am
A  geos/source/index/quadtree
A  geos/source/index/quadtree/IntervalSize.cpp
A  geos/source/index/quadtree/NodeBase.cpp
A  geos/source/index/quadtree/Root.cpp
A  geos/source/index/quadtree/Node.cpp
A  geos/source/index/quadtree/Key.cpp
A  geos/source/index/quadtree/Makefile.am
A  geos/source/index/quadtree/Quadtree.cpp
A  geos/source/index/quadtree/DoubleBits.cpp
A  geos/source/index/sweepline
A  geos/source/index/sweepline/SweepLineInterval.cpp
A  geos/source/index/sweepline/SweepLineIndex.cpp
A  geos/source/index/sweepline/Makefile.am
A  geos/source/index/sweepline/SweepLineEvent.cpp
A  geos/source/geomgraph
A  geos/source/geomgraph/PlanarGraph.cpp
A  geos/source/geomgraph/EdgeList.cpp
A  geos/source/geomgraph/DirectedEdgeStar.cpp
A  geos/source/geomgraph/Edge.cpp
A  geos/source/geomgraph/Depth.cpp
A  geos/source/geomgraph/Position.cpp
A  geos/source/geomgraph/TopologyLocation.cpp
A  geos/source/geomgraph/DirectedEdge.cpp
A  geos/source/geomgraph/EdgeNodingValidator.cpp
A  geos/source/geomgraph/GeometryGraph.cpp
A  geos/source/geomgraph/NodeFactory.cpp
A  geos/source/geomgraph/Label.cpp
A  geos/source/geomgraph/Quadrant.cpp
A  geos/source/geomgraph/NodeMap.cpp
A  geos/source/geomgraph/GraphComponent.cpp
A  geos/source/geomgraph/EdgeRing.cpp
A  geos/source/geomgraph/Node.cpp
A  geos/source/geomgraph/EdgeEndStar.cpp
A  geos/source/geomgraph/index
A  geos/source/geomgraph/index/SweepLineSegment.cpp
A  geos/source/geomgraph/index/MonotoneChainIndexer.cpp
A  geos/source/geomgraph/index/SegmentIntersector.cpp
A  geos/source/geomgraph/index/MonotoneChainEdge.cpp
A  geos/source/geomgraph/index/SimpleMCSweepLineIntersector.cpp
A  geos/source/geomgraph/index/SimpleSweepLineIntersector.cpp
A  geos/source/geomgraph/index/Makefile.am
A  geos/source/geomgraph/index/SimpleEdgeSetIntersector.cpp
A  geos/source/geomgraph/index/SweepLineEvent.cpp
A  geos/source/geomgraph/EdgeIntersectionList.cpp
A  geos/source/geomgraph/Makefile.am
A  geos/source/geomgraph/EdgeIntersection.cpp
A  geos/source/geomgraph/EdgeEnd.cpp
A  geos/source/Makefile.am
A  geos/source/headers
A  geos/source/headers/acconfig.h
A  geos/source/headers/geos.h
A  geos/source/headers/Makefile.am
A  geos/source/headers/geos/platform.h.vc
A  geos/source/headers/geos/precision.h
A  geos/source/headers/geos/version.h.vc
A  geos/source/headers/geos/operation.h
A  geos/source/headers/geos/algorithm
A  geos/source/headers/geos/algorithm/NotRepresentableException.h
A  geos/source/headers/geos/algorithm/InteriorPointArea.h
A  geos/source/headers/geos/algorithm/SIRtreePointInRing.h
A  geos/source/headers/geos/algorithm/HCoordinate.h
A  geos/source/headers/geos/algorithm/CentroidArea.h
A  geos/source/headers/geos/algorithm/PointInRing.h
A  geos/source/headers/geos/algorithm/SimplePointInAreaLocator.h
A  geos/source/headers/geos/algorithm/LineIntersector.h
A  geos/source/headers/geos/algorithm/RobustDeterminant.h
A  geos/source/headers/geos/algorithm/SimplePointInRing.h
A  geos/source/headers/geos/algorithm/CentralEndpointIntersector.h
A  geos/source/headers/geos/algorithm/InteriorPointLine.h
A  geos/source/headers/geos/algorithm/PointLocator.h
A  geos/source/headers/geos/algorithm/InteriorPointPoint.h
A  geos/source/headers/geos/algorithm/CentroidLine.h
A  geos/source/headers/geos/algorithm/MCPointInRing.h
A  geos/source/headers/geos/algorithm/CentroidPoint.h
A  geos/source/headers/geos/algorithm/ConvexHull.inl
A  geos/source/headers/geos/algorithm/Makefile.am
A  geos/source/headers/geos/algorithm/CGAlgorithms.h
A  geos/source/headers/geos/algorithm/MinimumDiameter.h
A  geos/source/headers/geos/algorithm/ConvexHull.h
A  geos/source/headers/geos/geomgraphindex.h
A  geos/source/headers/geos/opLinemerge.h
A  geos/source/headers/geos/io.h
A  geos/source/headers/geos/opBuffer.h
A  geos/source/headers/geos/nodingSnapround.h
A  geos/source/headers/geos/planargraph
A  geos/source/headers/geos/planargraph/Subgraph.h
A  geos/source/headers/geos/planargraph/PlanarGraph.h
A  geos/source/headers/geos/planargraph/algorithm
A  geos/source/headers/geos/planargraph/algorithm/Makefile.am
A  geos/source/headers/geos/planargraph/algorithm/ConnectedSubgraphFinder.h
A  geos/source/headers/geos/planargraph/DirectedEdgeStar.h
A  geos/source/headers/geos/planargraph/Makefile.am
A  geos/source/headers/geos/planargraph/NodeMap.h
A  geos/source/headers/geos/planargraph/Edge.h
A  geos/source/headers/geos/planargraph/GraphComponent.h
A  geos/source/headers/geos/planargraph/Node.h
A  geos/source/headers/geos/planargraph/DirectedEdge.h
A  geos/source/headers/geos/geomgraph.h
A  geos/source/headers/geos/indexChain.h
A  geos/source/headers/geos/util.h
A  geos/source/headers/geos/noding.h
A  geos/source/headers/geos/indexBintree.h
A  geos/source/headers/geos/indexStrtree.h
A  geos/source/headers/geos/profiler.h
A  geos/source/headers/geos/unload.h
A  geos/source/headers/geos/geomUtil.h
A  geos/source/headers/geos/opDistance.h
A  geos/source/headers/geos/platform.h.in
A  geos/source/headers/geos/version.h.in
A  geos/source/headers/geos/opValid.h
A  geos/source/headers/geos/opPolygonize.h
A  geos/source/headers/geos/opPredicate.h
A  geos/source/headers/geos/planargraph.h
A  geos/source/headers/geos/geom/Point.h
A  geos/source/headers/geos/geom/Geometry.h
A  geos/source/headers/geos/geom/MultiPolygon.inl
A  geos/source/headers/geos/geom/GeometryFilter.h
A  geos/source/headers/geos/geom/GeometryCollection.inl
A  geos/source/headers/geos/geom/CoordinateArraySequenceFactory.inl
A  geos/source/headers/geos/geom/MultiPoint.h
A  geos/source/headers/geos/geom/LineSegment.inl
A  geos/source/headers/geos/geom/Location.h
A  geos/source/headers/geos/geom/Envelope.inl
A  geos/source/headers/geos/geom/PrecisionModel.h
A  geos/source/headers/geos/geom/GeometryFactory.inl
A  geos/source/headers/geos/geom/CoordinateSequence.h
A  geos/source/headers/geos/geom/BinaryOp.h
A  geos/source/headers/geos/geom/CoordinateList.h
A  geos/source/headers/geos/geom/GeometryComponentFilter.h
A  geos/source/headers/geos/geom/Geometry.inl
A  geos/source/headers/geos/geom/Coordinate.h
A  geos/source/headers/geos/geom/Polygon.h
A  geos/source/headers/geos/geom/MultiLineString.h
A  geos/source/headers/geos/geom/LinearRing.h
A  geos/source/headers/geos/geom/IntersectionMatrix.h
A  geos/source/headers/geos/geom/CoordinateFilter.h
A  geos/source/headers/geos/geom/MultiPolygon.h
A  geos/source/headers/geos/geom/Triangle.h
A  geos/source/headers/geos/geom/CoordinateArraySequenceFactory.h
A  geos/source/headers/geos/geom/GeometryCollection.h
A  geos/source/headers/geos/geom/PrecisionModel.inl
A  geos/source/headers/geos/geom/CoordinateSequenceFactory.h
A  geos/source/headers/geos/geom/LineSegment.h
A  geos/source/headers/geos/geom/Envelope.h
A  geos/source/headers/geos/geom/LineString.h
A  geos/source/headers/geos/geom/CoordinateArraySequence.h
A  geos/source/headers/geos/geom/Coordinate.inl
A  geos/source/headers/geos/geom/Makefile.am
A  geos/source/headers/geos/geom/GeometryFactory.h
A  geos/source/headers/geos/geom/MultiLineString.inl
A  geos/source/headers/geos/geom/Dimension.h
A  geos/source/headers/geos/geom/GeometryList.h
A  geos/source/headers/geos/geom/util
A  geos/source/headers/geos/geom/util/PolygonExtracter.h
A  geos/source/headers/geos/geom/util/PointExtracter.h
A  geos/source/headers/geos/geom/util/GeometryTransformer.h
A  geos/source/headers/geos/geom/util/LinearComponentExtracter.h
A  geos/source/headers/geos/geom/util/GeometryEditor.h
A  geos/source/headers/geos/geom/util/GeometryEditorOperation.h
A  geos/source/headers/geos/geom/util/Makefile.am
A  geos/source/headers/geos/geom/util/ShortCircuitedGeometryVisitor.h
A  geos/source/headers/geos/geom/util/CoordinateOperation.h
A  geos/source/headers/geos/timeval.h
A  geos/source/headers/geos/indexQuadtree.h
A  geos/source/headers/geos/geosAlgorithm.h
A  geos/source/headers/geos/precision/CommonBitsOp.h
A  geos/source/headers/geos/precision/CommonBits.h
A  geos/source/headers/geos/precision/CommonBitsRemover.h
A  geos/source/headers/geos/precision/SimpleGeometryPrecisionReducer.h
A  geos/source/headers/geos/precision/EnhancedPrecisionOp.h
A  geos/source/headers/geos/precision/Makefile.am
A  geos/source/headers/geos/precision/GeometrySnapper.h
A  geos/source/headers/geos/precision/LineStringSnapper.h
A  geos/source/headers/geos/simplify
A  geos/source/headers/geos/simplify/DouglasPeuckerLineSimplifier.h
A  geos/source/headers/geos/simplify/TaggedLineString.h
A  geos/source/headers/geos/simplify/TaggedLinesSimplifier.h
A  geos/source/headers/geos/simplify/TaggedLineStringSimplifier.h
A  geos/source/headers/geos/simplify/DouglasPeuckerSimplifier.h
A  geos/source/headers/geos/simplify/LineSegmentIndex.h
A  geos/source/headers/geos/simplify/Makefile.am
A  geos/source/headers/geos/simplify/TopologyPreservingSimplifier.h
A  geos/source/headers/geos/simplify/TaggedLineSegment.h
A  geos/source/headers/geos/operation/polygonize
A  geos/source/headers/geos/operation/polygonize/PolygonizeGraph.h
A  geos/source/headers/geos/operation/polygonize/Polygonizer.h
A  geos/source/headers/geos/operation/polygonize/Makefile.am
A  geos/source/headers/geos/operation/polygonize/EdgeRing.h
A  geos/source/headers/geos/operation/polygonize/PolygonizeEdge.h
A  geos/source/headers/geos/operation/polygonize/PolygonizeDirectedEdge.h
A  geos/source/headers/geos/operation/valid
A  geos/source/headers/geos/operation/valid/ConsistentAreaTester.h
A  geos/source/headers/geos/operation/valid/IsValidOp.h
A  geos/source/headers/geos/operation/valid/RepeatedPointTester.h
A  geos/source/headers/geos/operation/valid/TopologyValidationError.h
A  geos/source/headers/geos/operation/valid/Makefile.am
A  geos/source/headers/geos/operation/valid/SimpleNestedRingTester.h
A  geos/source/headers/geos/operation/valid/QuadtreeNestedRingTester.h
A  geos/source/headers/geos/operation/valid/ConnectedInteriorTester.h
A  geos/source/headers/geos/operation/valid/SweeplineNestedRingTester.h
A  geos/source/headers/geos/operation/predicate
A  geos/source/headers/geos/operation/predicate/SegmentIntersectionTester.h
A  geos/source/headers/geos/operation/predicate/Makefile.am
A  geos/source/headers/geos/operation/predicate/RectangleContains.h
A  geos/source/headers/geos/operation/predicate/RectangleIntersects.h
A  geos/source/headers/geos/operation/overlay
A  geos/source/headers/geos/operation/overlay/ElevationMatrix.h
A  geos/source/headers/geos/operation/overlay/ElevationMatrixCell.h
A  geos/source/headers/geos/operation/overlay/MinimalEdgeRing.h
A  geos/source/headers/geos/operation/overlay/MaximalEdgeRing.h
A  geos/source/headers/geos/operation/overlay/LineBuilder.h
A  geos/source/headers/geos/operation/overlay/PolygonBuilder.h
A  geos/source/headers/geos/operation/overlay/OverlayNodeFactory.h
A  geos/source/headers/geos/operation/overlay/OverlayOp.h
A  geos/source/headers/geos/operation/overlay/PointBuilder.h
A  geos/source/headers/geos/operation/overlay/Makefile.am
A  geos/source/headers/geos/operation/overlay/FuzzyPointLocator.h
A  geos/source/headers/geos/operation/overlay/MinimalEdgeRing.inl
A  geos/source/headers/geos/operation/overlay/OverlayResultValidator.h
A  geos/source/headers/geos/operation/overlay/OffsetPointGenerator.h
A  geos/source/headers/geos/operation/overlay/EdgeSetNoder.h
A  geos/source/headers/geos/operation/EndpointInfo.h
A  geos/source/headers/geos/operation/GeometryGraphOperation.h
A  geos/source/headers/geos/operation/linemerge
A  geos/source/headers/geos/operation/linemerge/LineMergeGraph.h
A  geos/source/headers/geos/operation/linemerge/LineMerger.h
A  geos/source/headers/geos/operation/linemerge/EdgeString.h
A  geos/source/headers/geos/operation/linemerge/LineMergeEdge.h
A  geos/source/headers/geos/operation/linemerge/LineMergeDirectedEdge.h
A  geos/source/headers/geos/operation/linemerge/LineSequencer.h
A  geos/source/headers/geos/operation/linemerge/Makefile.am
A  geos/source/headers/geos/operation/Makefile.am
A  geos/source/headers/geos/operation/buffer
A  geos/source/headers/geos/operation/buffer/SubgraphDepthLocater.h
A  geos/source/headers/geos/operation/buffer/RightmostEdgeFinder.h
A  geos/source/headers/geos/operation/buffer/OffsetCurveSetBuilder.h
A  geos/source/headers/geos/operation/buffer/BufferBuilder.h
A  geos/source/headers/geos/operation/buffer/OffsetCurveBuilder.h
A  geos/source/headers/geos/operation/buffer/Makefile.am
A  geos/source/headers/geos/operation/buffer/BufferSubgraph.h
A  geos/source/headers/geos/operation/buffer/BufferOp.h
A  geos/source/headers/geos/operation/IsSimpleOp.h
A  geos/source/headers/geos/operation/distance
A  geos/source/headers/geos/operation/distance/DistanceOp.h
A  geos/source/headers/geos/operation/distance/ConnectedElementLocationFilter.h
A  geos/source/headers/geos/operation/distance/ConnectedElementPointFilter.h
A  geos/source/headers/geos/operation/distance/Makefile.am
A  geos/source/headers/geos/operation/distance/GeometryLocation.h
A  geos/source/headers/geos/operation/relate
A  geos/source/headers/geos/operation/relate/RelateNodeFactory.h
A  geos/source/headers/geos/operation/relate/RelateComputer.h
A  geos/source/headers/geos/operation/relate/RelateOp.h
A  geos/source/headers/geos/operation/relate/EdgeEndBundleStar.h
A  geos/source/headers/geos/operation/relate/EdgeEndBuilder.h
A  geos/source/headers/geos/operation/relate/RelateNode.h
A  geos/source/headers/geos/operation/relate/Makefile.am
A  geos/source/headers/geos/operation/relate/RelateNodeGraph.h
A  geos/source/headers/geos/operation/relate/EdgeEndBundle.h
A  geos/source/headers/geos/opRelate.h
A  geos/source/headers/geos/inline.h
A  geos/source/headers/geos/opOverlay.h
A  geos/source/headers/geos/io/ParseException.h
A  geos/source/headers/geos/io/ByteOrderDataInStream.h
A  geos/source/headers/geos/io/Writer.h
A  geos/source/headers/geos/io/ByteOrderValues.h
A  geos/source/headers/geos/io/WKBConstants.h
A  geos/source/headers/geos/io/WKBWriter.h
A  geos/source/headers/geos/io/StringTokenizer.h
A  geos/source/headers/geos/io/WKTWriter.h
A  geos/source/headers/geos/io/Makefile.am
A  geos/source/headers/geos/io/WKTReader.inl
A  geos/source/headers/geos/io/WKBReader.h
A  geos/source/headers/geos/io/ByteOrderDataInStream.inl
A  geos/source/headers/geos/io/WKTReader.h
A  geos/source/headers/geos/index/chain
A  geos/source/headers/geos/index/chain/MonotoneChainSelectAction.h
A  geos/source/headers/geos/index/chain/MonotoneChain.h
A  geos/source/headers/geos/index/chain/Makefile.am
A  geos/source/headers/geos/index/chain/MonotoneChainBuilder.h
A  geos/source/headers/geos/index/chain/MonotoneChainOverlapAction.h
A  geos/source/headers/geos/index/ItemVisitor.h
A  geos/source/headers/geos/index/bintree
A  geos/source/headers/geos/index/bintree/NodeBase.h
A  geos/source/headers/geos/index/bintree/Makefile.am
A  geos/source/headers/geos/index/bintree/Root.h
A  geos/source/headers/geos/index/bintree/Interval.h
A  geos/source/headers/geos/index/bintree/Node.h
A  geos/source/headers/geos/index/bintree/Bintree.h
A  geos/source/headers/geos/index/bintree/Key.h
A  geos/source/headers/geos/index/strtree
A  geos/source/headers/geos/index/strtree/AbstractNode.h
A  geos/source/headers/geos/index/strtree/ItemBoundable.h
A  geos/source/headers/geos/index/strtree/Boundable.h
A  geos/source/headers/geos/index/strtree/AbstractSTRtree.h
A  geos/source/headers/geos/index/strtree/SIRtree.h
A  geos/source/headers/geos/index/strtree/Makefile.am
A  geos/source/headers/geos/index/strtree/Interval.h
A  geos/source/headers/geos/index/strtree/STRtree.h
A  geos/source/headers/geos/index/Makefile.am
A  geos/source/headers/geos/index/quadtree
A  geos/source/headers/geos/index/quadtree/Quadtree.h
A  geos/source/headers/geos/index/quadtree/DoubleBits.h
A  geos/source/headers/geos/index/quadtree/IntervalSize.h
A  geos/source/headers/geos/index/quadtree/NodeBase.h
A  geos/source/headers/geos/index/quadtree/Makefile.am
A  geos/source/headers/geos/index/quadtree/Root.h
A  geos/source/headers/geos/index/quadtree/Node.h
A  geos/source/headers/geos/index/quadtree/Key.h
A  geos/source/headers/geos/index/SpatialIndex.h
A  geos/source/headers/geos/index/sweepline
A  geos/source/headers/geos/index/sweepline/SweepLineEvent.h
A  geos/source/headers/geos/index/sweepline/SweepLineInterval.h
A  geos/source/headers/geos/index/sweepline/SweepLineOverlapAction.h
A  geos/source/headers/geos/index/sweepline/Makefile.am
A  geos/source/headers/geos/index/sweepline/SweepLineIndex.h
A  geos/source/headers/geos/Makefile.am
A  geos/source/headers/geos/geomgraph/EdgeIntersection.h
A  geos/source/headers/geos/geomgraph/EdgeEnd.h
A  geos/source/headers/geos/geomgraph/PlanarGraph.h
A  geos/source/headers/geos/geomgraph/EdgeList.h
A  geos/source/headers/geos/geomgraph/DirectedEdgeStar.h
A  geos/source/headers/geos/geomgraph/DirectedEdge.inl
A  geos/source/headers/geos/geomgraph/Edge.h
A  geos/source/headers/geos/geomgraph/Depth.h
A  geos/source/headers/geos/geomgraph/Position.h
A  geos/source/headers/geos/geomgraph/TopologyLocation.h
A  geos/source/headers/geos/geomgraph/GeometryGraph.inl
A  geos/source/headers/geos/geomgraph/DirectedEdge.h
A  geos/source/headers/geos/geomgraph/EdgeNodingValidator.h
A  geos/source/headers/geos/geomgraph/GeometryGraph.h
A  geos/source/headers/geos/geomgraph/NodeFactory.h
A  geos/source/headers/geos/geomgraph/Label.h
A  geos/source/headers/geos/geomgraph/Quadrant.h
A  geos/source/headers/geos/geomgraph/index
A  geos/source/headers/geos/geomgraph/index/SimpleEdgeSetIntersector.h
A  geos/source/headers/geos/geomgraph/index/SweepLineEvent.h
A  geos/source/headers/geos/geomgraph/index/SweepLineSegment.h
A  geos/source/headers/geos/geomgraph/index/MonotoneChainIndexer.h
A  geos/source/headers/geos/geomgraph/index/MonotoneChain.h
A  geos/source/headers/geos/geomgraph/index/EdgeSetIntersector.h
A  geos/source/headers/geos/geomgraph/index/Makefile.am
A  geos/source/headers/geos/geomgraph/index/SegmentIntersector.h
A  geos/source/headers/geos/geomgraph/index/MonotoneChainEdge.h
A  geos/source/headers/geos/geomgraph/index/SimpleMCSweepLineIntersector.h
A  geos/source/headers/geos/geomgraph/index/SimpleSweepLineIntersector.h
A  geos/source/headers/geos/geomgraph/index/SweepLineEventObj.h
A  geos/source/headers/geos/geomgraph/Makefile.am
A  geos/source/headers/geos/geomgraph/NodeMap.h
A  geos/source/headers/geos/geomgraph/GraphComponent.h
A  geos/source/headers/geos/geomgraph/EdgeRing.h
A  geos/source/headers/geos/geomgraph/EdgeEndStar.h
A  geos/source/headers/geos/geomgraph/Node.h
A  geos/source/headers/geos/geomgraph/EdgeIntersectionList.h
A  geos/source/headers/geos/indexSweepline.h
A  geos/source/headers/geos/spatialIndex.h
A  geos/source/headers/geos/geom.h
A  geos/source/headers/geos/util/math.h
A  geos/source/headers/geos/util/AssertionFailedException.h
A  geos/source/headers/geos/util/IllegalArgumentException.h
A  geos/source/headers/geos/util/TopologyException.h
A  geos/source/headers/geos/util/CoordinateArrayFilter.h
A  geos/source/headers/geos/util/GEOSException.h
A  geos/source/headers/geos/util/Assert.h
A  geos/source/headers/geos/util/Makefile.am
A  geos/source/headers/geos/util/UniqueCoordinateArrayFilter.h
A  geos/source/headers/geos/util/GeometricShapeFactory.h
A  geos/source/headers/geos/util/UnsupportedOperationException.h
A  geos/source/headers/geos/noding/SegmentString.h
A  geos/source/headers/geos/noding/IteratedNoder.h
A  geos/source/headers/geos/noding/IntersectionFinderAdder.h
A  geos/source/headers/geos/noding/SinglePassNoder.h
A  geos/source/headers/geos/noding/FastNodingValidator.h
A  geos/source/headers/geos/noding/SegmentNodeList.h
A  geos/source/headers/geos/noding/IntersectionAdder.h
A  geos/source/headers/geos/noding/Noder.h
A  geos/source/headers/geos/noding/SegmentNode.h
A  geos/source/headers/geos/noding/MCIndexNoder.inl
A  geos/source/headers/geos/noding/SingleInteriorIntersectionFinder.h
A  geos/source/headers/geos/noding/MCIndexNoder.h
A  geos/source/headers/geos/noding/SimpleNoder.h
A  geos/source/headers/geos/noding/ScaledNoder.h
A  geos/source/headers/geos/noding/Makefile.am
A  geos/source/headers/geos/noding/snapround
A  geos/source/headers/geos/noding/snapround/MCIndexPointSnapper.h
A  geos/source/headers/geos/noding/snapround/SimpleSnapRounder.h
A  geos/source/headers/geos/noding/snapround/HotPixel.h
A  geos/source/headers/geos/noding/snapround/MCIndexSnapRounder.inl
A  geos/source/headers/geos/noding/snapround/Makefile.am
A  geos/source/headers/geos/noding/snapround/HotPixel.inl
A  geos/source/headers/geos/noding/snapround/MCIndexSnapRounder.h
A  geos/source/headers/geos/noding/SegmentString.inl
A  geos/source/headers/geos/noding/SegmentIntersector.h
A  geos/source/headers/geos/noding/NodingValidator.h
A  geos/source/headers/geos/noding/Octant.h
A  geos/source/util
A  geos/source/util/Assert.cpp
A  geos/source/util/Profiler.cpp
A  geos/source/util/GeometricShapeFactory.cpp
A  geos/source/util/Makefile.am
A  geos/source/util/UnsupportedOperationException.cpp
A  geos/source/util/math.cpp
A  geos/source/util/AssertionFailedException.cpp
A  geos/source/util/IllegalArgumentException.cpp
A  geos/source/noding
A  geos/source/noding/IntersectionFinderAdder.cpp
A  geos/source/noding/MCIndexNoder.cpp
A  geos/source/noding/SimpleNoder.cpp
A  geos/source/noding/FastNodingValidator.cpp
A  geos/source/noding/ScaledNoder.cpp
A  geos/source/noding/NodingValidator.cpp
A  geos/source/noding/SegmentNodeList.cpp
A  geos/source/noding/IntersectionAdder.cpp
A  geos/source/noding/Makefile.am
A  geos/source/noding/Octant.cpp
A  geos/source/noding/SegmentNode.cpp
A  geos/source/noding/snapround
A  geos/source/noding/snapround/MCIndexSnapRounder.cpp
A  geos/source/noding/snapround/Makefile.am
A  geos/source/noding/snapround/MCIndexPointSnapper.cpp
A  geos/source/noding/snapround/SimpleSnapRounder.cpp
A  geos/source/noding/snapround/HotPixel.cpp
A  geos/source/noding/IteratedNoder.cpp
A  geos/source/noding/SegmentString.cpp
A  geos/source/noding/SingleInteriorIntersectionFinder.cpp
A  geos/source/examples
A  geos/source/examples/CoordinateSequencesExample.cpp
A  geos/source/examples/CPCLException.cpp
A  geos/source/examples/CustomPointCoordinateSequence.cpp
A  geos/source/examples/CustomCoordinateSequenceExample.cpp
A  geos/source/examples/Makefile.am
A  geos/source/examples/CustomCoordinateSequenceExample.h
A  geos/tools
A  geos/tools/geos-config.in
A  geos/tools/Makefile.am
A  geos/tests
A  geos/tests/unit
A  geos/tests/unit/operation
A  geos/tests/unit/operation/overlay
A  geos/tests/unit/operation/overlay/FuzzyPointLocatorTest.cpp
A  geos/tests/unit/operation/overlay/OverlayResultValidatorTest.cpp
A  geos/tests/unit/operation/overlay/OffsetPointGeneratorTest.cpp
A  geos/tests/unit/operation/IsSimpleOpTest.cpp
A  geos/tests/unit/operation/distance
A  geos/tests/unit/operation/distance/DistanceOpTest.cpp
A  geos/tests/unit/algorithm
A  geos/tests/unit/algorithm/CGAlgorithms
A  geos/tests/unit/algorithm/CGAlgorithms/computeOrientationTest.cpp
A  geos/tests/unit/algorithm/CGAlgorithms/isCCWTest.cpp
A  geos/tests/unit/algorithm/CGAlgorithms/isPointInRingTest.cpp
A  geos/tests/unit/algorithm/ConvexHullTest.cpp
A  geos/tests/unit/algorithm/PointLocatorTest.cpp
A  geos/tests/unit/geom
A  geos/tests/unit/geom/MultiPolygonTest.cpp
A  geos/tests/unit/geom/MultiPointTest.cpp
A  geos/tests/unit/geom/TriangleTest.cpp
A  geos/tests/unit/geom/CoordinateArraySequenceFactoryTest.cpp
A  geos/tests/unit/geom/LocationTest.cpp
A  geos/tests/unit/geom/LineSegmentTest.cpp
A  geos/tests/unit/geom/Geometry
A  geos/tests/unit/geom/Geometry/isRectangleTest.cpp
A  geos/tests/unit/geom/Geometry/coversTest.cpp
A  geos/tests/unit/geom/EnvelopeTest.cpp
A  geos/tests/unit/geom/LineStringTest.cpp
A  geos/tests/unit/geom/CoordinateArraySequenceTest.cpp
A  geos/tests/unit/geom/GeometryFactoryTest.cpp
A  geos/tests/unit/geom/CoordinateListTest.cpp
A  geos/tests/unit/geom/DimensionTest.cpp
A  geos/tests/unit/geom/CoordinateTest.cpp
A  geos/tests/unit/geom/PolygonTest.cpp
A  geos/tests/unit/geom/MultiLineStringTest.cpp
A  geos/tests/unit/geom/PointTest.cpp
A  geos/tests/unit/geom/LinearRingTest.cpp
A  geos/tests/unit/geom/IntersectionMatrixTest.cpp
A  geos/tests/unit/index
A  geos/tests/unit/index/quadtree
A  geos/tests/unit/index/quadtree/DoubleBitsTest.cpp
A  geos/tests/unit/io
A  geos/tests/unit/io/ByteOrderValuesTest.cpp
A  geos/tests/unit/io/WKBReaderTest.cpp
A  geos/tests/unit/Makefile.am
A  geos/tests/unit/utility.h
A  geos/tests/unit/precision
A  geos/tests/unit/precision/GeometrySnapperTest.cpp
A  geos/tests/unit/precision/LineStringSnapperTest.cpp
A  geos/tests/unit/precision/SimpleGeometryPrecisionReducerTest.cpp
A  geos/tests/unit/capi
A  geos/tests/unit/capi/GEOSSimplifyTest.cpp
A  geos/tests/unit/capi/GEOSCoordSeqTest.cpp
A  geos/tests/unit/simplify
A  geos/tests/unit/simplify/DouglasPeuckerSimplifierTest.cpp
A  geos/tests/unit/simplify/TopologyPreservingSimplifierTest.cpp
A  geos/tests/unit/geos_unit.cpp
A  geos/tests/unit/util/UniqueCoordinateArrayFilterTest.cpp
A  geos/tests/unit/noding
A  geos/tests/unit/noding/SegmentPointComparatorTest.cpp
A  geos/tests/unit/noding/SegmentNodeTest.cpp
A  geos/tests/unit/noding/SegmentStringTest.cpp
A  geos/tests/bigtest
A  geos/tests/bigtest/GeometryTestFactory.cpp
A  geos/tests/bigtest/bigtest.h
A  geos/tests/bigtest/Makefile.am
A  geos/tests/bigtest/TestSweepLineSpeed.cpp
A  geos/tests/xmltester
A  geos/tests/xmltester/TestValid2.xml
A  geos/tests/xmltester/stmlf-cases-20070119.xml
A  geos/tests/xmltester/testrunner.sh
A  geos/tests/xmltester/hexwkb.xml
A  geos/tests/xmltester/Stackwalker.cpp
A  geos/tests/xmltester/TestValid.xml
A  geos/tests/xmltester/markup
A  geos/tests/xmltester/markup/MarkupSTL.cpp
A  geos/tests/xmltester/markup/MarkupSTL.h
A  geos/tests/xmltester/hole_from_shell.xml
A  geos/tests/xmltester/TestInteriorPoint.xml
A  geos/tests/xmltester/linemerge.xml
A  geos/tests/xmltester/TestCentroid.xml
A  geos/tests/xmltester/CTS.cpp
A  geos/tests/xmltester/TestBufferExternal.xml
A  geos/tests/xmltester/XMLTester.h
A  geos/tests/xmltester/TestValid2-big.xml
A  geos/tests/xmltester/testLeaksBig.xml
A  geos/tests/xmltester/hole_red.xml
A  geos/tests/xmltester/SimpleWKTTester.cpp
A  geos/tests/xmltester/TestIsValid.xml
A  geos/tests/xmltester/heisenbugs.xml
A  geos/tests/xmltester/WKTIn
A  geos/tests/xmltester/badguy3.xml
A  geos/tests/xmltester/WKTOut
A  geos/tests/xmltester/TestRobustOverlayFixed.xml
A  geos/tests/xmltester/buffer_snapround.xml
A  geos/tests/xmltester/Stackwalker.h
A  geos/tests/xmltester/robustness.xml
A  geos/tests/xmltester/fme.xml
A  geos/tests/xmltester/stmlf-cases-20061020.xml
A  geos/tests/xmltester/buffer.xml
A  geos/tests/xmltester/XMLTester.cpp
A  geos/tests/xmltester/Makefile.am
A  geos/tests/xmltester/test.xml
A  geos/tests/Makefile.am
A  geos/tests/tut
A  geos/tests/tut/tut.h
A  geos/tests/tut/tut_reporter.h
A  geos/tests/tut/Makefile.am
A  geos/tests/tut/tut_restartable.h
A  geos/doc
A  geos/doc/Doxyfile.in
A  geos/doc/Makefile.am
A  geos/doc/example.cpp
A  geos/doc/example.tosql
A  geos/doc/README
A  geos/swig
A  geos/swig/python
A  geos/swig/python/tests
A  geos/swig/python/tests/test_geometry.py
A  geos/swig/python/tests/example.py
A  geos/swig/python/tests/Makefile.am
A  geos/swig/python/tests/TESTING.txt
A  geos/swig/python/tests/runtests.py
A  geos/swig/python/geos.py
A  geos/swig/python/geos.pth
A  geos/swig/python/geos_wrap.cxx
A  geos/swig/python/python.i
A  geos/swig/python/Makefile.am
A  geos/swig/ruby
A  geos/swig/ruby/test
A  geos/swig/ruby/test/test_coordinate_sequence.rb
A  geos/swig/ruby/test/test_helper.rb
A  geos/swig/ruby/test/geos_tests.rb
A  geos/swig/ruby/test/test_relations.rb
A  geos/swig/ruby/test/test_srid.rb
A  geos/swig/ruby/test/test_operations.rb
A  geos/swig/ruby/test/test_combinations.rb
A  geos/swig/ruby/test/test_version.rb
A  geos/swig/ruby/test/test_io.rb
A  geos/swig/ruby/test/Makefile.am
A  geos/swig/ruby/test/test_buffer.rb
A  geos/swig/ruby/test/test_geometry.rb
A  geos/swig/ruby/test/example.rb
A  geos/swig/ruby/test/test_envelope.rb
A  geos/swig/ruby/geos_wrap.cxx
A  geos/swig/ruby/ruby.i
A  geos/swig/ruby/Makefile.am
A  geos/swig/Makefile.am
A  geos/swig/geos.i.in
A  geos/capi
A  geos/capi/test.expected
A  geos/capi/geos_c.cpp
A  geos/capi/testrunner.sh
A  geos/capi/test.wkt
A  geos/capi/Makefile.am
A  geos/capi/geos_c.h.in
A  geos/capi/geostest.c
A  geos/web
A  geos/web/style.css
A  geos/web/index.html
 U geos
Checked out revision 2038.
