[geos-devel] svn checkout problem
Paul Ramsey pramsey at refractions.net
Mon Dec 10 17:30:12 EST 2007
The geos-svn snapshot includes a ./configure built on the server for
you delectation.
P
On 10-Dec-07, at 2:24 PM, Hugh Jennings wrote:
>>> Hi,
>>> I was hoping to get the current version of your code but I am
>>> experiencing a small problem. The configure script does not
>>> appear to be being checked out when I try to get your code.
>>> I believe am using the command as stated on your website.  I have
>>> attached a file which shows the command and the results.
>>> I would appreciate any suggestions as to what I can do differently.
>> Hugh,
>> I believe you are expected to run the autogen.sh script in the geos
>> directory to generate configure and related derived files.
>> You may need reasonably modern versions of autoconf and automake
>> installed
>> on your system for this to work.
>> Best regards,
> Frank,
> Thanks.  I am not a programmer.
> Cheers.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
