[geos-devel] svn checkout problem
Mateusz Loskot mateusz at loskot.net
Tue Dec 11 07:43:46 EST 2007
Frank Warmerdam wrote:
> Hugh Jennings wrote:
>> Hi,
>> I was hoping to get the current version of your code but I am
>> experiencing a small problem. The configure script does not appear to
>> be being checked out when I try to get your code.
>> I believe am using the command as stated on your website.  I have
>> attached a file which shows the command and the results.
>> I would appreciate any suggestions as to what I can do differently.
> Hugh,
> I believe you are expected to run the autogen.sh script in the geos
> directory to generate configure and related derived files.
This is perfectly correct.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
