[geos-devel] Geos 3.0.0 RC 4 on OS X 10.5
Richard Greenwood richard.greenwood at gmail.com
Wed Dec 12 22:12:29 EST 2007
Mateusz and William;
Thanks for your help. With the two modifications, it compiled without
error. Unfortunately, neither modification appear to be included in
geos-3.0.0rc5.
Rich
On Dec 12, 2007 10:08 AM, Mateusz Loskot <mateusz at loskot.net> wrote:
> Richard Greenwood wrote:
> > I am trying to build Geos 3.0.0 RC 4 on OS X 10.5.  HCoordinate.cpp
> > fails because finite() is not defined. Changing it to the FINITE()
> > macro fixes the problem. I notice that Revision 1.19 switched it from
> > the macro to the function.
> > I tried to post a bug report in Trac, but my OSGeo account seems to be
> > completely foobar.
> Richard,
> This issue has been reported to the Trac and already fixed:
> http://trac.osgeo.org/geos/ticket/162
> If you have troubles with your OSGeo account, please follow the section
> about updating, perhaps it will help:
> http://www.osgeo.org/osgeo_userid/
> > Hmm, now the build is failing on:
> > XMLTester.cpp: In function 'void tolower(std::string&)':
> > XMLTester.cpp:75: error: 'std::tolower' is not a valid template
> > argument for type 'int ()(int)' because function 'int tolower(int)'
> > has not external linkage
> Please, try to apply the fix I explained here:
> http://lists.osgeo.org/pipermail/geos-devel/2007-November/003125.html
> It's been also reported as ticket, but I've not applied this fix to the
> SVN yet:
> http://trac.osgeo.org/geos/ticket/163
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Richard Greenwood
www.greenwoodmap.com
