[geos-devel] Problem with building 3.0.0rc
Paul Ramsey pramsey at refractions.net
Fri Dec 28 11:35:47 EST 2007
The tail of my ./configure looks like this, what does yours look like?
config.status: creating swig/geos.i
config.status: creating swig/Makefile
config.status: creating swig/python/Makefile
config.status: creating swig/python/tests/Makefile
config.status: creating swig/ruby/Makefile
config.status: creating swig/ruby/test/Makefile
config.status: creating tests/Makefile
config.status: creating tests/bigtest/Makefile
config.status: creating tests/unit/Makefile
config.status: creating tests/tut/Makefile
config.status: creating tests/xmltester/Makefile
config.status: creating tools/Makefile
config.status: creating tools/geos-config
config.status: creating source/headers/config.h
config.status: source/headers/config.h is unchanged
config.status: creating source/headers/geos/platform.h
config.status: source/headers/geos/platform.h is unchanged
config.status: executing depfiles commands
Swig: false
Python: false
Ruby: false
On Dec 28, 2007, at 7:44 AM, Sean Gillies wrote:
> Charlie Savage wrote:
>> Sean Gillies wrote:
>>> I'm encountering a problem with the 3.0 release candidate that
>>> blocks a
>>> build on my Ubuntu 6.10 i686.
>>> "configure --prefix=/tmp; make; make install" bails out here:
>>> I don't understand why the install-pkgpythonPYTHON target is
>>> attempted
>>> when I haven't enabled the swig python bindings. Any idea what's
>>> up here?
>> Thinking about this more, I think the way this was setup is to run
>> SWIG
>> if the bindings file (*.cxx) is older than any changes to the SWIG
>> interface files (*.i).
>> That should not be the case unless you've modified the interface
>> files,
>> or they've somehow been modified in SVN since the generation of the
>> *.cxx files.
>> Charlie
> I wonder then if I'm experiencing an unintended side effect. I've not
> enabled swig python or ruby and swig is not run to produce wrappers
> (good), but the machine still steps into swig/python/Makefile and
> executes targets therein, even attempting to byte compile nonexistant
> modules.
> IMO, unless swig/python is explicitly enabled, make should skip that
> branch of the tree. Or am I overlooking something?
> Sean
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
