[geos-devel] Problem with building 3.0.0rc
Charlie Savage cfis at savagexi.com
Fri Dec 28 13:36:35 EST 2007
> Same here.
> The mkinstalldirs script appears to be buggy on this particular
> platform. One shift too many. Strangely, the 3.0rc builds fine on
> another Ubuntu 6.10 i686 of mine. Same bash version even.
> I suppose I could try to fix mkinstalldirs, but it seems like it should
> be simpler and more foolproof for the build to ignore swig/python
> alltogether unless it is explicitly enabled.
It would be good to know what is going wrong.  Strk and I did (and Mark
a bit) did spend some time trying to make sure this works, and it seems
like you've found some bug in the code or our logic.
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20071228/373b011b/smime-0001.bin
